Limiting B.W on Serial interface
m.eldemery
Hi ALl
I have two cisco routers connected over E1 via two serial interface on each other , I wants to limit B.W on the serial interface .
Thanks in advance
griffijo
Do you mean that you want limit the bandwidth that certain applications can use? The are a variety of QoS mechanisms that you could use for that. Could you explain a little more?
Kevin Dorrell
Level 10
Level 10
You can use rate-limit or "CAR" for this. Here is the doc:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_configuration_guide_chapter09186a00800ca594.html
Kevin Dorrell
Luxembourg
