Line is UP protocol is UP.....Still not working :(
visheshverma
Hi Everyone !!!
I need some help desperately.
I have a Cisco 7200 Series Router which is connected to a Cisco 3750 switch as following:-
Cisco 7200 [FASTETHERNET 0/1] (195.100.121.1)--------------------------------------(195.100.121.2) [FASTETHERNET 0/0] Cisco 3750
Everything was working fine for a couple of months. However the connection stopped working today suddenly without any reason. I don't know why (no logs generated, nothing on SNMP server)
The LINE and PROTOCOL on both router and switch are UP. There are no ERRORS or CRC counters.
Also I cannot even ping Cisco 7200 IP 195.100.121.1 from itself.
PROD_7200# ping 195.100.121.1
Sending 5, 100-byte ICMP Echos to 195.100.121.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Any suggestions about what is the issue here and how to solve it ?
Vishesh
Sending 5, 100-byte ICMP Echos to 100.100.100.100, timeout is 2 seconds:
5 Replies 5
Sandeep Choudhary
Hi Vishes,
Have you tried to change the cable?
have u tried shut and no shut on both interface ?
just show the output:
sh int fa 0/1
amohaida
Hi Vishes,
could you please share "show interface" from both sides ? show ip arp 195.100.121.2 from the router side?
if possible please enable debug arp and try to ping and share the debug output as well.
thanks,
Ahmad.
visheshverma
Hi Guys !!!
I have tried changing the Cisco 7200 with another one but NVRAM wasn't big enough to load the full config of this router
Reloaded the main router a couple of times (no success).
Outputs from Cisco 7200........ I am getting similar output from 3750 nothing unusual:-
OUTPUT FOR show interface fa0/1
Fast Ethernet 0/1 is up, line protocol is up
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Half-duplex, 10Mb/s, 100BaseTX/FX
  ARP type: ARPA, ARP Timeout 4:00:00
  Last input 00:00:01, output 00:00:06, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 50231232 bits/sec, 239826 packets/sec
  5 minute output rate 2032438 bits/sec, 143026 packets/sec
     498528 packets input, 754771392 bytes
     Received 4386 broadcasts, 0 runts, 0 giants, 0 throttles
     46 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog
     238904 packets output, 348799846 bytes, 0 underruns
     28 output errors, 0 collisions, 14 interface resets
     8 lost carrier, 0 no carrier
OUTPUT FOR show ip arp 195.100.121.2
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  195.100.121.2               0   Incomplete      ARPA
Also for debug arp I haven't got any reply message for arp request for 195.100.121.2 or vice versa on Cisco 3750. Only arp request messages on both devices.
But the one thing that is troubling me the most is that I can't ping the router 7200(FA0/1) from the router itself.
How is this happening when the interface line and protocol both are up..
It is a production router of my company and was working fine since it was deployed. Also the I don't have any issues with other interfaces of this router they are working fine and their connected devices too....
Hi Vishes,
Half duplex 10 mbps means cable in the most of cases. Change it and if you did, just hardcore the speed:
Int fa0/1
Speed 100
Duplex full
End
Do this on both sides and let me know
Alessio
visheshverma
Hi Guys !!!
Thanks for the helpful replies....
We figured out the issue, it was because of an ACL permit ip any any applied to a crypto-map,
All the traffic Input/Output was being encrypted for VPN because of which self ping was not working.
Anyways....after 18 hours of continous TSHOOT....We finally caught it.
Apologies for late reply.....got busy in recreating the issue on the LAB for documentation.
CHEERS
