line protocol down even though speed/duplex setting and cabling are correct
sgrg07
I am trying to setup a home lab. 2x2811 Refurb routers and a few catalyst 2960 switches. I was able to sucessfully get an address from the dhcp address pool from the ISP modem.
In the begining I was able to connect the two routers, but now I can't get them to connect. I have checked the duplex/speed setting in the ports (f0/0, f0/1) and also the cables .. but still not working. I just cant figure out what the issue could be ( I haven't had too much hands on experience with routers/switches before, so I having a brain freeze moment.)
I am new to this forum, not sure if im posting in the right thread.. any advice would be appreciated.
Many Thanks in advance
Sandesh
Julio E. Moisa
In order to interconnect 2 routers you need a crossover cable.
crossover cable image
Now if you are connecting the routers using the switch you can use a straight cable, and enable the interfaces using the no shutdown command under the interfaces.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
