line vty 0 <max>
mike-brooks
I am putting together a small script (series of commands in a Notepad .txt file) to be run from cli on a variety of Cisco Catalyst switches and routers.  Because the number of vty lines varies on the different platforms, I would like to be able to specify
line vty 0 15
except instead of just putting the actual number 15, have the command put in the highest number of vty lines possible.  How can I do this without creating a different script for each different switch, router, vg, etc?
Mike
Richard Burts
Mike
If this is a set of commands that you will copy and paste from Notepad then it seems that your only alternative is to pick a number and put it into the command or create a set of the scripts with one for each platform type. If you want to get into an interactive scripting environment then you could specify a variable and check for platform and set the variable appropriately. But that is a much more complex thing to write.
Rick
Rick
Most equipment supports up to 5 vty so You can write it like this
line vty 0 4
 < your commands>
line vty 5 15
< your commands>
this way, for equipment that doesn't support vty range up to 15, you got it to work with the 0 to 4 and then just an error.
/Mikael
