: %LINEPROTO-5-UPDOWN: Line protocol on Interface
DWAM_2
Level 3
Level 3
On 2950 with version c2950-i6q4l2-tar.121-22.EA10a.tar, I have got follow messages :
Oct 12 13:47:03.971: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/29, changed state to down
Oct 12 13:47:05.971: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/29, changed state to up
Oct 12 13:51:41.957: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/34, changed state to down
Oct 12 13:51:46.169: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/34, changed state to up
Oct 12 13:52:36.828: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/34, changed state to down
Oct 12 13:52:38.836: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/34, changed state to up
Oct 13 06:11:00.154: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/38, changed state to down
Oct 13 06:11:02.174: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/38, changed state to up
Oct 13 06:11:27.218: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/38, changed state to down
Oct 13 06:11:29.226: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/38, changed state to up
Oct 15 23:19:46.948: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/38, changed state to down
Oct 15 23:19:48.960: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/38, changed state to up
Oct 15 23:20:12.772: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/38, changed state to down
Oct 15 23:20:14.772: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/38, changed state to up
We have changed cables, switch but the behaviours occur.
All ideas are welcome.
Best regards.
ankbhasi
Hi Friend,
Can you confirm what is connected to fa0/29,34 and 38 interfaces? Only these interfaces flap or any other interfaces also?
Can you also update "sh run interface fa0/29" from your switch?
Ankur
Thank you for you answer.
It takes on random interfaces.
We have changed the switch and behaviours occur again.
I have upgraded the version to the last.
On the older switch, it affects the giga interface :
Oct 10 06:14:40.498: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down Oct 10 06:14:43.806: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
This interface is connected to another switch (backbone switch !)
The show run for this interface is :
interface FastEthernet0/29
switchport access vlan 5
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
Thank you
