Link flaps between two gigabit ethernet links
Hi All,
We have two switches C3560G-48TS and C3750G-12S(is a stack switch). They are connected via two gigabit ethernet links bundled into a port channel. gi 0/47 & gi 0/48 of C3560G-48TS are connected to gi 1/0/3 & gi 2/0/3 resply. We have intermittent link flaps for only gi 0/47 connected to gi 1/0/3. Below is the log files from C3750G-12S and for C3560G-48TS logs are not showing.
So, requesting all to help me find the discrepancy, if it is somewhere. Appreciate your time.
C3750G-12S:
Apr 12 17:01:38.653 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to up
Apr 12 17:02:22.225 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to down
Apr 12 17:02:23.240 EDT: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/3, changed state to down
Apr 12 17:02:25.672 EDT: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/3, changed state to up
Apr 12 17:02:31.343 EDT: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/3, changed state to down
Apr 12 17:02:43.624 EDT: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/3, changed state to up
Apr 12 17:02:49.480 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to up
For C3560G-48TS: show interface cmd output:
sh int gi 0/47
GigabitEthernet0/47 is up, line protocol is up (connected)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 7w4d
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 14000 bits/sec, 16 packets/sec
  5 minute output rate 14000 bits/sec, 15 packets/sec
     258378059 packets input, 160471077187 bytes, 0 no buffer
     Received 33424530 broadcasts (8587908 multicasts)
     476 input errors, 255 CRC, 0 frame, 0 overrun, 0 ignored
C3750G-12S: show interface cmd output:
#sh int gi 1/0/3
GigabitEthernet1/0/3 is up, line protocol is up (connected)
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP
  Last input 00:00:12, output 00:00:01, output hang never
  5 minute input rate 14000 bits/sec, 14 packets/sec
  5 minute output rate 17000 bits/sec, 22 packets/sec
     648452143 packets input, 617654556023 bytes, 0 no buffer
     Received 1461988 broadcasts (712355 multicasts)
     2 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
C3560G-48TS: interface config:
#sh run int gi 0/47
Building configuration...
Current configuration : 251 bytes
interface GigabitEthernet0/47
 switchport trunk native vlan 999
 switchport mode trunk
 bandwidth 1000000
 speed 1000
 channel-group 16 mode active
C3750G-12S: interface config:
sh run int gi 1/0/3
Current configuration : 338 bytes
interface GigabitEthernet1/0/3
 srr-queue bandwidth share 10 10 60 20
 queue-set 2
 priority-queue out
 mls qos trust dscp
 auto qos voip trust
Hi kaushik,
I can see some input erros on gi0/47. So next step would be to check physical layer.
Try replacing cable, SFP etc on both sides.
Also regading 3560 not showing link down in logs, you may try enabling under gi1/0/3
logging event link-status
Hope this helps and kindly rate my post if it is useful to you.
Madhu.
Hi Madhu,
Thanks for your reply. I will get the cables verified first and then go for SFP module. But the configuration of the interfaces, are they fine? I just have a little doubt about the manual configuration of bandwith and speed of GigabitEthernet0/47 of C3560G-48TS.
Also please note that the speed of C3560G-48TS's Gi0/47 is 100MB and Gi0/48 is 1000MB. And, since they were participating in etherchannel so speed of Gi0/47 has been changed about 1 year back, to 1000MB as can be seen in the configuration that I had provided above. So, is that also causing any type of issue?
Thanks for your time and help.
