Linksys SRW2048 connection problems
snickasaurus
So I have read about proper procedure involving the connection between a console cable and Hyperterminal. I have also tried plugging into a network port to obtain an IP Address but nothing seems to work. When powering on the switch I see that it lights up, hear fans spin and assume it has booted properly. I'm using Hyperterminal on Windows Xp Pro SP3 and I've also tried minicom in Fedora. Is there any other trick someone could offer?
And just FYI Hyperterminal was set to the proper:
Bits per second: 38400
Data bits: 8
Parity: None
Stop Bits: 1
Flow Control: None
Any help or ideas would be greatly appreciated!!
ebarticel
Level 4
Level 4
Change bits per second to 9600
