LLDP (Layer 2 protocol) tunneling not working
benjaminscherer
we are using a WS-C3750-48TS as a transparent switch for multiple separated networks. Now the switch shall also forward incoming LLDP frames to the appropriate egress ports. Therefore i have added the command "l2protocol-tunnel lldp" to each interface, where this feature is needed. So my configuration looks like (excerpt):
spanning-tree mode pvst
no spanning-tree vlan 1,4051-4062
vlan internal allocation policy ascending
vlan 4051-4062
interface FastEthernet1/0/1
 switchport access vlan 4051
 switchport mode dot1q-tunnel
 no keepalive
 no cdp enable
interface FastEthernet1/0/2
 no keepalive
 no cdp enable
I have tested this setup with SW version c3750-ipbasek9-mz.122-55.SE8 and c3750-ipbasek9-mz.122-55.SE9. The result was that no incoming LLDP frames have been counted by the switch (checked with "show l2protocol-tunnel") and also no LLDP frames have been forwarded. As a countercheck i have done the same procedure with STP (l2protocol-tunnel stp) and CDP (l2protocol-tunnel cdp), which was successful. So in principial the L2 tunneling is working but not for LLDP. Do i need to add something in addition in the configuration? Or is there a SW version which is known to work correctly? Or is this not fully implemented since LLDP tunneling is not explicitly mentioned in user manual?
Best regards
Benjamin
5 Replies 5
nkarthikeyan
Level 7
Level 7
You can check the cisco feature navigator to find with your requirement.
http://www.cisco.com/c/en/us/support/switches/catalyst-3750-series-switches/tsd-products-support-series-home.html?referring_site=bodynav
I believe 12.2.55SE version of IOS supports that. But better if you could search in that tool and findout with the requirement,
for 12.2.55SE
Can someone explain the difference between l2protocol forward <> and l2protocol tunnel <> ?? how are the packets edited on the ingress and egress PE nodes ??
nagamune2
I am testing L2 protocol tunnel for LLDP on ME3400 and cant make it work.
ME3400#4-fa0/1--------------fa0/1 ME3400#2-Gi0/1--------
( Customer Switch)                                ( Edge Switch )
Customer Switch
ME3400_4#sh running-config interface fastEthernet 0/1
Building configuration...
Current configuration : 48 bytes
interface FastEthernet0/1
 port-type nni
end
ME3400_4#sh ll
ME3400_4#sh lldp in
ME3400_4#sh lldp interface fas
ME3400_4#sh lldp interface fastEthernet 0/1
FastEthernet0/1:
    Tx: enabled
    Rx: enabled
    Tx state: IDLE
    Rx state: WAIT FOR FRAME
ME3400_4#
Edge Switch
ME3400_2#sh running-config interface fastEthernet 0/1
Current configuration : 103 bytes
end
ME3400_2#
ME3400_2#show l2protocol-tunnel  interface fastEthernet 0/1
COS for Encapsulated Packets: 5
Port                Protocol    Shutdown  Drop      Encaps    Decaps    Drop
                                Threshold Threshold Counter   Counter   Counter
Fa0/1               cdp           ----      ----            1         0         0
                    lldp          ----      ----            0         0         0 >>>>>>>>>>>>>no lldp counters
                    stp           ----      ----           27         0         0
ME3400_2#
I tried other configuration as well but it did not work.
Can anyone please help me with correct config. Below are the SW details I am using :-
Switch Ports Model              SW Version            SW Image
*    1 26    ME-3400-24TS-A     12.2(54)SE            ME340x-METROACCESSK9-M
Naga
lldp needs to be enabled globally before the lldp l2protocol-tunnel will work.
lldp run
Hello Perko,
it makes sense so the "provider side" switch needs to enable LLDP at global level in order to be able to process and tunnel LLDP frames received on 802.1Q tunnel interface(s).
Reading the thread I thought that it was an IOS version issue.
thanks for your valuable feedback
Best Regards
Giuseppe
