Load balance not happening in BGP
Sanjib Pradhan
Dear Friends,
As per I know local BGP process may implement equal-cost load-balancing to the paths that:
  • Have the same set of path attributes up to the MED (weight, Local Preference, Origin, MED)
  • Are of the same type (both learned via iBGP or eBGP)
  • Have the same IGP cost to reach their NEXT_HOP IP address
If the above conditions are met andmaximum-paths [ibgp]is  configured under the BGP process, BGP will install multiple equal-cost  routes into the local RIB and use them for load-balancing. We call the  above condition as load-balancing conditions for BGP.
As all the above criteria are matched still BGP is not doing load balance. Please find below routing table:
R1:
R1#sh ip bgp
BGP table version is 4, local router ID is 40.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*>i192.168.1.0      20.1.1.2                 0    100      0 i
* i                        30.1.1.1                 0    100      0 i
R1#sh ip route
Gateway of last resort is not set
     20.0.0.0/24 is subnetted, 1 subnets
R       20.1.1.0 [120/1] via 10.1.1.2, 00:00:03, FastEthernet0/0
     40.0.0.0/24 is subnetted, 1 subnets
C       40.1.1.0 is directly connected, FastEthernet0/1
     10.0.0.0/24 is subnetted, 1 subnets
C       10.1.1.0 is directly connected, FastEthernet0/0
B    192.168.1.0/24 [200/0] via 20.1.1.2, 00:12:01
     30.0.0.0/24 is subnetted, 1 subnets
R       30.1.1.0 [120/1] via 40.1.1.2, 00:00:15, FastEthernet0/1
router bgp 100
no synchronization
bgp log-neighbor-changes
neighbor 10.1.1.2 remote-as 100
neighbor 40.1.1.2 remote-as 100
maximum-paths 2
no auto-summary
Please help....!!!!!!!   why BGP is not load balancing here????
R1#traceroute 192.168.1.1
Tracing the route to 192.168.1.1
  1 10.1.1.2 88 msec 60 msec 28 msec
  2 20.1.1.2 104 msec 56 msec 120 msec
Sanjib
Jon Marshall
Sanjib
Looking at your diagram all routers are in the same AS. If so this is IBGP and so under your BGP router config -
no maximum-paths 2
maximum-paths ibgp 2
Jon
Jon Marshall
Sanjib
no maximum-paths 2
Jon
Dear Jon,
Thank you so much.
When I changed the configuration BGP is now loadbalancing. But in configuartion Max-path showing as 1 instead of 2.
R1#sh ip pro | sec bgp
Routing Protocol is "bgp 100"
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  IGP synchronization is disabled
  Automatic route summarization is disabled
  Neighbor(s):
    Address          FiltIn FiltOut DistIn DistOut Weight RouteMap
    12.1.1.2
    13.1.1.3
Maximum path: 1
  Routing Information Sources:
    Gateway         Distance      Last Update
    13.1.1.3             200      00:01:12
    12.1.1.2             200      00:02:15
  Distance: external 20 internal 200 local 200
Sanjib
