01-22-2009 01:54 PM - edited 03-06-2019 03:35 AM
Scenario:
- Two Sites
- Each site has two routers connecting both the sites
- At each site, Router 1 has two leased lines connected and Router 2 has one. Thereby making it three WAN links between the sites.
How can I achieve load balancing on the WAN links to ensure uniform link utilization. Only one destination exists for the communication between the sites. Packet sharing is a risky option. What is the safest way to load share on the WAN links in the given scenario.
01-22-2009 02:41 PM
Are you using a routing protocol?
01-23-2009 04:35 AM
No. We will be using static routes only.
01-24-2009 07:10 AM
I readup some materials. Please let me know if the following seems to be a good option
1) Use multilink PPP for aggregation of serial links on the routers across both the sites
2) Configure GLBP/HSRP on the inside ethernet interfaces on all the routers.
With #1, even utilization of the WAN links within the router shall be ensured. And with #2, the traffic hitting the router on the inside will be load balanced.
Please advise.
