Local Captive portal in ewc controller without ISE AD
I have a 9115 ewc controllter and like other OEMs like Ruckus and Aruba i want to configure local Guest captive portal SSID, but internal webauth is not working.
i checked cisco documents too but all are with either ISE or LDAP or external web page
I just want internal web page for SSID redirect and internal Guest user for access
18 Replies 18
MHM
in policy section i don't find any  mobilty tab like in blog
this need only for HA, this step is OP
MHM
After connecting ssid it got directly connected and not popoing login page but when i do https://<virtual-ip> it opened the login page
MHM
@Sharanjeet_Kumar
  As per your description below, you might be missing the ACL configuration. IF you are able to reach the Guest portal by using the WLC virtual IP, but, you are not getting there when testing from wifi network, that means the redirect is not taking place.
 You need to deny the traffic on port 80. Take a close look on "4. Configuring Pre-Auth Web Authentication ACL (GUI)"
Hi @Flavio Miranda
I have added the ACL and applied to the guest ssid but still not redirecting
perhaps i am missing a little thing
still when after ssid got connected, i search https://192.0.2.1 then the cisco page opened
PHH!!!
Also, when i apply the pre-auth ACL in advance security section then neither redirecting happened nor https://192.0.2.1 opened
after removing ACL redirecting still not happened but i can able to do htttps://192.0.2.1 and cisco default login webauth page was opening
@Sharanjeet_Kumar
 You need the ACL.
What about DNS? When you connect to the guest SSID, are you receiving DHCP and DNS? Can you test?
Yes, i already applied the ACL in the pre-auth field
and i have DHCP configured on my cisco switch and after connecting i am receiving IP with DNS and DHCP IPs.
Got it. Your DHCP comes from the Switch and what about your DNS server? Is it local ?
There are two things that usually cause problem with the URL redirect in Guest networks. Access List and DNS.
https://wifininjas.net/2019/10/24/wn-blog-017-cisco-c9800-local-web-auth-config/
ACL is maybe more importante.
You can see that the ACL allows you to communicate with DNS server, DHCP server and deny everything else.
The deny is responsible for the redirect. You can change that and deny the HTTP/HTTPS traffic insteadl
Pay attention with browser. Sometimes the redirect occours only with HTTP traffic but browser now a days will always use HTTPS first.
Make sure when connected to the guest, you can reach your DNS server. You can run nslookup command to test the DNS.
We don't have any DNS server in infra, we are using 8.8.8.8 as DNS server
we have simple topology
ISP-->Router-->Switch(DHCP SERVER)-->WLC/AP-->Lan/WiFi Users
I have denied http and https traffic in ACL but still no luck
Now it is redirecting but opening just some edge page
ACL is now good also
client statrus
@Sharanjeet_Kumar
It is redirecting? Did you authenticated before you get this MSN page?
