12-23-2024 10:54 PM
I have a 9115 ewc controllter and like other OEMs like Ruckus and Aruba i want to configure local Guest captive portal SSID, but internal webauth is not working.
i checked cisco documents too but all are with either ISE or LDAP or external web page
I just want internal web page for SSID redirect and internal Guest user for access
12-27-2024 11:03 AM
sometimes it is re-directing, sometimes it is not
and after connecting ssid edge browser is opening 'MSN page' but no any option of login i mean default cisco page is not opening
12-27-2024 11:15 AM
Remove any active session on the WLC.
Clear browser data.
Use different browser.
If you are hitting the MSN page whithout authentication, the ACL is not working
12-27-2024 11:18 AM - edited 12-27-2024 11:18 AM
my ACL is correct but perhaps you are right <ACL is not working> as i was getting log of ACL error
i don't know if i am doing anything wrong
and in mobiles phones no any redirection happening neither in iphone nor in android
12-27-2024 11:31 AM
Can I see the ACL logs?
