Log time and system time difference
giosportech
Community Member
The time stamped in logs and system time of our router has an 8 hour time difference. Below is a sample output of the time difference:
Nov 25 05:00:49.312: %SYS-5-CONFIG_I: Configured from console by network on vty0
router#sh clock
13:07:34.208 GMT Thu Nov 25 2004
How can I make them synchronized? I've already set the ntp server and timezone. Have I overlooked something?
Router Specs:
Platform:2621XM
IOS: 12.3(7)T4
Modules Connected: NM-16AH-V2 at slot 1
Running Config:
(some lines deleted for security purposes)
version 12.3
service password-encryption
hostname dostras
boot-start-marker
boot-end-marker
clock timezone GMT 8
no network-clock-participate slot 1
no network-clock-participate wic 0
aaa authentication login default group radius local
aaa authentication login localauth local
aaa authentication ppp default if-needed group radius local
aaa authorization exec default group radius local
aaa authorization exec localauth local
aaa authorization network default group radius local
aaa accounting delay-start
aaa accounting exec default start-stop group radius
aaa accounting network default start-stop group radius
aaa session-id common
ip subnet-zero
ip cef
ip dhcp pool DIALUP
no ip domain lookup
ip domain name dost.gov.ph
no ftp-server write-enable
modemcap entry 1
interface Loopback0
ip address 1.1.1.1 255.255.255.0
interface FastEthernet0/0
description Connection to Catalyst
duplex auto
speed auto
interface Group-Async1
ip unnumbered FastEthernet0/0
dialer in-band
dialer idle-timeout 600
dialer-group 1
ntp broadcast client
ntp multicast client
ntp multicast
async mode dedicated
peer default ip address dhcp-pool DIALUP
ppp max-bad-auth 3
ppp authentication chap
group-range 33 48
no ip classless
ip http server
dialer-list 1 protocol ip permit
control-plane
line con 0
line 33 48
line aux 0
line vty 0 4
transport output all
ntp clock-period 17180361
ntp server 202.90.129.206
en
Kevin Dorrell
Level 11
Level 11
The confusion here is the clock timezone GMT 8 command. For reference, here is the documentation:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/ffun_r/ffrprt3/frf012.htm#wp1018092
The timezone you put in should be your timezone. Since you have configured an offset of 8 hours from UTC, I am guessing you are in Western Australia, so you would want something like clock timezone WST 8. GMT is Greenwich mean time, which is almost equivalent to UTC. But that is only cosmetic.
Do the cosmetic change I suggested. It may just be a matter of the presentation of the sh clock. I don't know whether you did that command at your lunchtime, or late evening. I think it was your lunchtime, and the logs are stamping the UTC. The GMT is just confusing you.
(If you ever get a dot in front of your log timestamp entries, then the NTP is not synchronised. But that is not the case here.)
You need the keyword localtime in your service timestamps.
Kevin Dorrell
Luxembourg
Kevin,
The command service timestamps logging/debug localtime did the trick.
Thanks!
