Logging command options on 3560G
keith.giles
Visitor
Hi all,
I have a 3560G running IOS 12.2(35)SE5 and I'm thinking that a certain logging command is not supported. I was hoping someone could confirm.
For example, I want to change the port to send Syslogs.
In the CLI, I can type "Logging host x.x.x.x" but I want to add "transport udp port 5141 session-id hostname"  However, this syntax after the IP address is not recognized.
Is this just an issue with the IOS version or am I missing something?
Any help is much appreciated!
Reza Sharifi
I know the 3850 series do support it,but not sure if this platform support "Logging host x.x.x.x transport udp port 5141 session-id hostname" command.
Here are all the reference guides for newer versions, but I don't see the command being supported.
http://www.cisco.com/c/en/us/support/switches/catalyst-3560-series-switches/products-command-reference-list.html
Reza Sharifi
Upgrading the CISCO IOS to 12.2(55) SE10 resolved the issue.
