Logging configuration on cisco 4507
Arijit Das
Hello guys,
I have one query rgarding logging configuration.
Is there any option to configure cisco 4507 to genrate log alert when cpu utilization or port utilization reaches above certain percentage.
Please help.
Arijit
Raju Sekharan
Hi Arijit,
You can use "process cpu threshold type" command if you want to create syslog message when the CPU raises above a certain percentage
reference link :
http://www.cisco.com/en/US/docs/ios/netmgmt/configuration/guide/nm_cpu_thresh_notif.pdf
Rmon is another option to generate alerts
http://www.cisco.com/en/US/tech/tk961/technologies_configuration_example09186a0080094478.shtml
if you want to deect any event and take an action ot, you can use EEM
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6555/ps6815/config_guide_eem_configuration_for_cisco_integrated_services_router_platforms.html
Thank you
Raju
Thanks Raju,
Can you please give an example of alert log configuration when predefined utilization threshold of a switch port expires.
Arijit
