Showing results forĀ
Search instead forĀ
Did you mean:Ā
logical topology to physical topology
solemdoms5
I want to make sure my understanding is correct . so please help me out .
I saw the logical topology attached the file name is logical topology .
I wondered how the logical topology cange into physical topology .
and I made the physical topology attached .
Are both of topologys chart is the same  ?
If i was wrong , Could you fix it ?
Regards.
acampbell
Hi.
Both topologies could easily be the same.
Your switch in the middle of the physical
would be running multiple vlans.
Your logical diagram should contain the
IP subnet & addressing scheme and perhaps the
switch vlan numbers.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
