Looking for a device, suggestions?
Gulliveig
Good morning,
I like to replace these 3 devices
- an ADSL2 Gateway (with 4 ports),
- an 8 ports switch, and
- an AP (802.11g)
with a single device containing the functionality of all of them.
It should feature
- at least 8 ports, better 16 though, as 7 are already in use;
- can feature 802.11n if it supports 802.11g as well (only 1 device here is making use of a decicated 802.11n AP/Repeater, all the others use the 2.4 GHz AP)
Is there any Cisco device fulfilling these requirements? Link to the product would be appreciated.
Thank you in advance.
Herbert
Hi Herbert,
If 8 ports are ok maybe cisco 1801 ADSL over POTS, here the link:
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/ps6184/product_data_sheet0900aecd8028a95f_ps5853_Products_Data_Sheet.html
1802 model is ADSL over ISDN.
Best regards,
Alex
EDIT: Wireless is A/B/G. Pls rate if helpful.
