Looking for info re. programming NAT, VLAN
bHubTel1610c
I'm trying to program a 1711 Cisco router for small office, home LAN using Cable broadband cable modem.  I'm looking for info or docs about programming for NAT.
The router has a 4 port switchcard (4esw)
The way I understand it, I'll program Fastethernet port  0 (F0) to connect to cable modem, using dhcp and NAT outside.
F1 -F4 will run via VLAN as NAT inside.  My problem is that I'm fuzzy on details.
Do I also need to set up a default route ?
If you can point me in the right direction, I would appreciate it.
Thanks!
Bruce
Orlando, FL
2 Accepted Solutions
roman.alex
If You configure outside interface to get ip addr from DHCP server, You no need to set default gateway.
How to configure NAT look at the CISCO cookbook or http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
About VLANs: it depends on network topology (one trunk link to switch or tagged interfaces in 2-3-4 networks).
However, use search on cisco.com. It's better solution )
GL!
Reza Sharifi
Hi Bruce,
Follow the link in this discussion and the relevant config is also there.  Adjust the interfaces to fit your router.
https://supportforums.cisco.com/thread/2093227?tstart=0
Come back with more questions and post your config
Reza
roman.alex
GL!
Reza Sharifi
Hi Bruce,
Reza
