08-24-2016 02:56 AM - edited 03-08-2019 07:07 AM
Hello, we currently run VSS at one of our sites and there was an access edge switch connected to it via layer 2. The access edge switch had two individual trunks. One was going to one physical 6800 (VSS) and one was going to the other. Since there are two boxes but they act as one logical box. Anyway, a loop was created and traffic was crawling. Those trunks were passing the data and wireless AP vlan's. Lets say vlan 2 and vlan 3 for example. This issue was causing high CPU process and our wireless voice clients were impacted the most as traffic was struggling to pass through the switch, any commands we tried were taking a long time to actually process. The issue was resolved after placing the two separate trunks on that access edge switch into a port channel going to the VSS.
I am just kinda confused because VSS is two physical switches turned into one logical switch, shouldnt spanning tree block any redundant links?
I am assuming when it comes to VSS any dual uplinks to a switch should be in a port channel/MEC, right?
Can someone clarify for me please, I think the VSS and how STP works within the VSS is throwing me off.
08-24-2016 03:20 AM
Yes best practice to have port-channels unless the switch is orphan link by itself to one chassis for some reason , the switch as you see acts as one unit so like anything dual linked like that a loop will occur if one link is not blocking at L2 or bundled acting as one total link
Best practice doc VSS
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Campus/VSS30dg/campusVSS_DG/VSS-dg_appa-configs.html
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-virtual-switching-system-1440/109547-vss-best-practices.html#vss_best
08-24-2016 03:27 AM
Hello Mark, thanks for your answer and providing the links. In your opinion, why do you think it did not block originally when it was dual linked? I would think that dual links passing the same vlans, 1 link should be blocked.
08-24-2016 04:06 AM
so first I have never setup a VSS without using po unless single linked so I am taking a bit of a guess here without labbing it and debugging to confirm exactly whats happening at L2, I have a few in place we always follow best practice with the pos
I would have thought as its a single logical entity that it would block the link as it would see the loop
did you not get any alerts for stp in logs ? maybe something irregular happenied with the bpdus crossing the vsl
The active chassis runs Spanning Tree Protocol (STP). The standby chassis redirects STP BPDUs across the VSL to the active chassis.
Spanning Tree Configuration Best Practices with VSS
03-24-2017 01:13 AM
It looks like same symptom happened in my last implementation. My scenario only happened to EOL switches so I assume it is compatibility issue since there no latest firmware available to fix it.
