loop guard and root guard
carl_townshend
Hi all
I have a bit of confusion where I should enable these 2 features, some sites saying different things,
I have 2 distribution switches and then access switches dual connected to each, should I enable root guard on all edge ports and not the uplink ports or, and only enable loopguard on the uplink ports to the distribution layer?
please explain your reasoning why, this will help me
many thanks
Carl
Reza Sharifi
Carl,
Please refer to this link for understanding how loop guard and root guard works:
http://www.cisco.com/univercd/cc/td/doc/product/core/cis7600/ios121_8/swcg/stp_enha.htm#1033825
Reza
