loop guard & udld agressive - etherchannel
Can anybody pls share whether I need to enable loop guard & udld agressive config on Ether-Channel
what is the ciso recomendation / Pls share the document for the same
Also pls share in case the same is required on Physical interface or on Port-channel interface,
As per my understanding it is required on Physical interface
Br/Subhojit
6 Replies 6
Leo Laohoo
Can anybody pls share whether I need to enable loop guard & udld agressive config on Ether-Channel what is the ciso recomendation / Pls share the document for the same
I would never enable loopguard but UDLD will depend on the link.
If my physical links are fibre optic, then UDLD is ideal for this sort of condition and link.
I will NEVER use or recommend UDLD on copper links.
Link: STP Enhancements using Loop Guard and BPDU Skew Detection Features # Loop Guard versus UDLD
"(...) UDLD might be more flexible in the case of unidirectional links on EtherChannel. In this case, UDLD disables only failed links, and the channel should remain functional with the links that remain. In such a failure, the loop guard puts it into loop-inconsistent state in order to block the whole channel."
Rolf
Can we use both the feature to take the advantage of the same
If we use both, whether any performance degradation expected or not
Br/Subhojit
You still haven't responded to my basic question:  What is your link?  Copper or Fibre optic?
My link is fiber
Br/Subhojit
My link is fiber
Enable UDLD or even FAST UDLD.  No need for Loopguard.
