Loop
saquib.tandel
Level 7
Level 7
what configuration steps is needed to avoid loop on the network, its a Client / Server topology
Catalyst 4507 acting as core and distribution. All access switches are 2950, 2960 series.
thanks
ST
2 Accepted Solutions
loop prevention is needed as soon as you form a triangle or square
triange : access switch 1 --- to core 1  ------core 2 ------to switch 1
By default classical STP is enabled so no worries but it's better to activate RSTP
configuration on all switches the required vlans:
vlan 2
name test
vlan 3
name test2
vlan 4
name test4
spanning-tree mode rapid-pvst
vtp mode transparent
vtp domain ! can be the same or different on other switches
on the 4500 core distribution switch
previous config +
vlan 2,3,4 priority 8192     <--- this will make the 4500 as root of the entire l2 network
if you've a second core/distribution switch
vlan 2,3,4 priority 12288 <-- create a backup STP root
if you don't have a secondary core/distribution, don't configure it on another access switch
Ports connecting to an end user or server
interface fas0/1
spanning-tree portfast
spanning-tree bpduguard enable
switchport mode access
please rate helpful posts
VTP pruning makes more efficient use of trunk bandwidth by reducing unnecessary flooded traffic.
This you need when you need set of VLANS should travers on the link rest of all will not, so that the available bandwidth will use in sufficient way.
Regarding spanning tree config on access layers, what you mentioned in your previous post is enough.
Please rate the helpfull posts.
Naidu.
7 Replies 7
Latchum Naidu
A loop in your network can bring down the whole network.
I would suggest STP to use in your scenario which can avoid a loop by using Spanning Tree protocol (STP).
Please see the below linke for more details.
http://www.petri.co.il/csc_preventing_network_loops_with_stp_8021d.htm
Also find the below link for the discussion to avoid network loops.
http://www.experts-exchange.com/Networking/Network_Management/Network_Analysis/Q_22647147.html
And this link is for your implement of STP in your network.
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_configuration_example09186a008009467c.shtml
Hope this clear for you.
Naidu.
what is best practise from Cisco where you got One 4507 and 20 Access switches, none of the acccess switches got redundant connection.
Two of the 2960 switches are cascaded to one of the access-switch directly connected to Core (4507)
Numnber of Vlans are 12
I have gone through these, still confused which best fits or best practise from cisco. Spanning-tree commands needs to be applied on VTP server and client both or just Server.
Spanning-tree mode rapid-pvst
spanning-tree mode MST
spanning-tree bpduguard default
spanning-tree bpdufilter default
error-disable
uplink fast
thanks
ST
vlan 2
name test
vlan 3
name test2
vlan 4
name test4
previous config +
interface fas0/1
Thank you for supporing.
Do this config looks ok, any more suggestions on Loop and uplink config consideration
On 4500
it would be
VTP mode Server
VTP domain Cisco
VTP password XXX
vlan 2,3,4,5,6,7,8,9  ....20 ( just to show there are around 20 vlans )
interface vlan 2
ip add 192.168.1.1 255.255.255.0
interface vlan 5
ip address 172.16.1.1 255.255.255.252
Spanning-tree vlan 1 prority 0
Spanning-tree portfast bpduguard default
interface fa 3/1
description Connected to Web01-Server
switchport access vlan 2
interface fa 3/23
description Connected to "Wireless-Lan-Controller"
interface fa 3/24
description Connected to "Service-Provider CPE"
switchport access vlan 5
Interface gi 0/1
description "connected to Access-Switch-EX01"
switchport mode trunk
Interface gi 0/2
description "connected to Access-Switch-Floor_2"
Interface gi 0/3
description "connected to Access-Switch-Floor_3"
router ospf 1
network 192.168.1.0 255.255.255.0
network 172.16.1.0 255.255.255.252
network 172.20.2.0 255.255.254.0
network 172.16.16.0 255.255.252.0
On Access_Switches 2960
VTP mode client
VTP domain Cisco
VTP password XXX
interface gi0/0
description "connected to Core"
This looks fine.
Please do this config and check.
Naidu.
I need clarification
What is difference between "vlan 2,3,4 priority 8192" and "spanning-tree vlan 1 priority 0"
Do I need "VTP Prunning"
also
4500-----------------connected-------------------Access_sw1------------------------Access_sw2
sw1 gi 0/0 is connected to 4500 as a trunk
sw1 gi 0/1 is connected to acces-sw2 as a trunk
do I need to configure access_sw2 with all relevant spanning-tree config / VTP config  or just switchport mode trunk config is enough
Naidu.
