Loopback cable for gig port
sonisdreams
                   Hi All,
How to create loopback cable for gig copper port (cisco 6513).
I have tried the following loopback cable:
1-3
2-6
and
1-4
2-5
and
1-3
2-6
4-7
5-8
but interface was not up .Pls suggest if any other option.
This interface is fine. this is just for testing purpose to create loop back cable for future use.
Deep
Ganesh Hariharan
Deepesh Soni wrote:
                   Hi All,
1-3
2-6
and
1-4
2-5
and
1-3
2-6
4-7
5-8
Deep
Hello Deep,
If you are handy with building ethernet cables, the simple explanation is;
1. Redirect Pin 1 to Pin 3 and Pin 2 to Pin 6.
2. Make sure you create tight twists to account for signal interference at such a short length.
Hope it Help !!
Ganeshh Iyer
Rate if it Helps...
Hi Ganeshh,
I have already tried as I have mentioned. not working
Deepesh Soni wrote:
Hi Ganeshh,
Oh hh anyway check out the below link hope it helps
http://www.ciscoconsole.com/networking/how-to-create-a-rj45-ethernet-loopback-cable.html/
Ganeshh Iyer
rate if it helps ...
