LOOPGUARD OVER POINT TO POINT WAN LINKS
jeffreywatson
So I have a question about loopguard over point to point WAN links
If at Site A we have Rtr-A to Switch A  ( Vlan 1)    OVER WAN   Switch B ( Vlan 1)  Rtr-B
I think we do have spanning tree enabled on the switch ports so one side is the root bridge.
There is more to the network than this - but the short story is that during a failover condition the point to point link
can become saturated for several minutes by multicast.And i have noticed that the Switch port puts the Switch A ports in LOOP INCONSISTENT  state  which it eventually recovers.
So I'm guessing we're temp not getting BPDU's back and forth.
Should I disable Spanning tree on the point to point links - or just disable loopguard or enable BPDU Filter ?
There are no other devices on the segment.
If SW A is the root port for the segment and stops receiving BPDUs for max age -  will it go into LOOP INCONSISTENT state also just like a non desig or Alt port will?
thank you
j
Hello
Yes it will -
As SW-A is the root port so that will be one receiving the bpdus from SW-B Designated port as you so rightly stated
When the port stops receiving the bpdu, STP will think your network is loopfree and transition another alternate or backup port into a forwarding state thus loopguard will kick in on this root port as it will see the potential loop and put into an inconsistent state.
I wouldn't suggest disabling stp or removing loopguard, but maybe some storm control for multicast
res
Paul
Kind Regards
Paul
Thank you
just curious but if these are point to point links then what benefit is loopguard?
I can understand leaving SPT enabled just in case.
