06-04-2024 01:53 AM
configured a new switch - 9200 - stack of two) , and after a reboot, it loses all configurations
#sh version
Switch Ports Model SW Version SW Image Mode
* 1 56 C9200-48P 17.09.05 CAT9K_LITE_IOSXE INSTALL
2 56 C9200-48P 17.09.05 CAT9K_LITE_IOSXE INSTALL
#sh boot
Switch#sh boot
Switch 1
Current Boot Variables:
BOOT variable does not exist
Boot Variables on next reload:
BOOT variable = flash:packages.conf;
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
#Switch#show version | include register
Configuration register is 0x102
I had planned to go install the switches tomorrow
Solved! Go to Solution.
06-04-2024 03:19 AM
no system ignore startupconfig switch all <<- I think you need this command
MHM
06-04-2024 02:09 AM
      - Review this document and correct your settings where needed :
                      https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/216850-configuration-register-equivalent-clis-i.html
M.
06-04-2024 02:30 AM - edited 06-04-2024 02:30 AM
thanks marce1000
I looked at the document. On the other hand, I don't know what the optimal ( or normal) configurations are? I don't know why, I made changes to the configuration, I restarted 3 times and now it keeps the configuration.
06-04-2024 03:11 AM
Post the complete output to the command "sh rom-var".
06-04-2024 03:19 AM
MHM
06-04-2024 07:05 AM
#sh romvar
ROMMON variables for Active Switch
ABNORMAL_RESET_COUNT=0
AUTOBOOT_COUNT=0
AUTOBOOT_STATE=0
AUTO_SWITCH_CONSOLE_DISABLE=0
BAUD=9600
BOOT=flash:packages.conf;
BOOT_DEVICE_MODE=catalyst
BSI=0
CLEI_CODE_NUMBER=INM9V00ERA
CONSOLE_MIRRORING_DISABLE=0
DC_COPY=yes
MAC_ADDR=CC:ED:4D:76:76:80
MANUAL_BOOT=no
MODEL_NUM=C9200-48P
MODEL_REVISION_NUM=H0
MOTHERBOARD_ASSEMBLY_NUM=73-18791-04
MOTHERBOARD_REVISION_NUM=D0
MOTHERBOARD_SERIAL_NUM=FOC255307H4
NO_CONSOLE=0
POE_DB_INFO=73-18775-01B0FOC25520LM0
RANDOM_NUM=470438464
ROMMON_AUTOBOOT_ATTEMPT=3
ROMMON_BOARDID=0x320
ROMMON_BOARDREV=0x400
ReloadReason=Install RET_2_RCALTS=1713423603
SWITCH_IGNORE_STARTUP_CFG=0
SWITCH_NUMBER=1
SWITCH_PRIORITY=14
SYSTEM_SERIAL_NUM=FOC255307H4
TAN_NUM=68-101784-01
TEMPLATE=advanced
USB_DB_INFO=73-18785-04A0FOC25520F08
USB_DISABLE=0
VERSION_ID=V01
It seems ok now, I restarted the stack twice, I keep the configuration well
