Low disk space updating 9200L stack switches
ezejazz
I have a 9200L-48P-4X switch stacked with a 9200L-48P-10G. When attempting to update to version 17.09.05, I encounter a "low disk" error on the 1G switch, while the 10G switch does not have this issue. The update image copies to the switch, but when I attempt to boot from it, I get the low disk warning. Any suggestions?
9 Replies 9
ezejazz
@Flavio Miranda I run the Install remove inactive but no help.
Chek the flash, you probably have old files there that the command is not removing.  remove it manually.
Leo Laohoo
Reboot the entire stack and re-start the process.
ezejazz
There is 1039429 KB of free space, but only 769784 KB is available. I don't know what is taking up space. I even erased Vram and started fresh.
Post the complete output to the following commands:
dir crashinfo:
dir crashinfo:*.gz
ezejazz
Those commands don't shows much:
SWITCH-TEST-01#dir crashinfo:
Directory of crashinfo:/
14657 drwx 61440 Nov 15 2024 14:00:01 +00:00 tracelogs
15 -rw- 20292747 Nov 15 2024 13:59:21 +00:00 SWITCH-TEST-01_1_RP_0_trace_archive_0-20241115-135906.tar.gz
14 -rw- 9696025 Nov 14 2024 13:12:42 +00:00 Switch_2_RP_0-system-report_2_20241114-131236-UTC.tar.gz
13 -rw- 7791853 Aug 5 2021 19:31:21 +00:00 Switch_2_RP_0-system-report_2_20210805-193116-UTC.tar.gz
11 -rw- 8846499 Aug 5 2021 19:10:03 +00:00 Switch_1_RP_0-system-report_1_20210805-190959-UTC.tar.gz
12 -rw- 0 Dec 12 2020 04:36:51 +00:00 koops.dat
825638912 bytes total (701374464 bytes free)
SWITCH-TEST-01#dir crashinfo:*.gz
Directory of crashinfo:/*.gz
IF these two files are of no use, delete all the files in the crashinfo: folder to free up some space.
del /f /r crashinfo:*.gz
del /f /r crashinfo:/tracelogs/.
