Low memory I/O on 2960s
Hello all,
we recently installed cisco PI 1.3 and on the "Top N Memory Utilization" dashboard I am seeing that many of our 2960s switches have high memory I/O.
Most of them are running
c2960s-universalk9-mz.122-55.SE3
c2960s-universalk9-mz.122-58.SE2.bin
c2960s-universalk9-mz.150-2.SE5
I am not seeing any weird behavior yet (failing ssh sessions etc), but I found many posts about high memory utilization on 2960 switches.
https://supportforums.cisco.com/discussion/11682111/2960-s-high-memory-use-1502se
https://supportforums.cisco.com/discussion/11283871/12258se2-2960-cause-memory-leaks
The bug CSCts52797 only applies to IOS 12.2(58)SE. What is wrong with the other switches? What can I check? Since PI 1.3 has many other problems, I do not know if what I am seeing is correct (probably an IOS bug) or faulty PI behavior.
Please advise!!!
Thank you in advance,
Katerina
7 Replies 7
Paolo Marchiori
Same here. My PI 2.1 says my top mem-usage devices are the 2960S, all of them on I/O.
But I suspect the thing is normal - some sort of preallocation, and https://supportforums.cisco.com/discussion/11327186/high-io-memory-utilization-2960 seems to support this idea.
My switches are all on 12.2(58)SE2 which is the highest IOS 12 release; however 12.2(55)SE9 being far more recent (mrach 2014) is probably our best bet.
If I were in you, I wouldn't keep 12.2(55)SE3 anyway - better go and upgrade to SE9 while you aren't in production yet.
Hi Paolo,
I upgraded the IOS on a switch to c2960s-universalk9-mz.122-55.SE9. Same issue! High I/O memory utilization (83%). So downgrade or upgrade????
The cisco site suggests 15.0.2-SE6. I will try that and see...
Upgraded to c2960s-universalk9-mz.150-2.SE6.
Same thing. I/O memory utilization 83%. So I come to understand that this is normal behavior...(?)
I am open to suggestions...
Thanks in advance,
Katerina
Hi.Katerina
I also have this problem, High I/O memory .
the switch is WS-C2960S-48TS-L,and old version 12.2-55 SE7,then upgrade to c2960s-universalk9-mz.150-2.SE6.
all of two versions is  High I/O memory.
Hi, i opened tac case and they said this is normal behaviour... So there is nothing else to do!
Katerina
is any of you people currently at cisco live by any chance?
I'm going to Cisco Live Melbourne (Australia) 2015.
