low memory in 3750G-24T
arturo.reyna
Hi, I had a problem with a stack of WS-C3750G-24T, I wasn't able to login by telnet, when I connected with console I saw "low memory" messages.
It seems stack was working, services in that swicthes were fine, it also sent syslog messages to one server but none related to this memory condition.
Any idea? I will really apreciate your help.
Regards.
Joseph W. Doherty
Can't say whether this will help, but 3750 supports different resouce templates that allocates resources differently. You might want to check whether you're using the best template for your usage.
joachim_chan
what's the version of your ios?
I have a case where the 3650 is running on c3560-ipservicesk9-mz.122-44.SE.bin and it's getting the same message.
