Mac address flapping issue
ruesch-eng
Level 2
Level 2
I am seeing mac address flapping on my 2960 switch. I entered a static mac address table entry, but that did not resolve the issue. The flapping still continues. And when I do a sh mac address-table command, I see that both a static entry and a dynamic entry exist for that address. I am running 12.2(35)SE5. How can I resolve this issue? Thanks.
Reza Sharifi
There could be multiple things that can cause MAC flapping.
Take a look at this paper
http://www.cisco.com/en/US/partner/products/hw/switches/ps663/products_tech_note09186a00801434de.shtml#subtopic1k
Reza
Ganesh Hariharan
Mac-address flapping issue can come from host/server end,just check out the following things from server/host end that both the NIC are connected to different swiches and are in ACTIVE/PASSIVE fashion from server/host end.If both the nic are configured in Active/Active fashion then there will be mac flapping messages can come on switches.In order to troubleshoot just check the serve end configuration of NIC and try with Active/Passive mode from server end for load balancing.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
