MAC addresses of a switch attached to VLANs - generic question
hostettle
I'm going to try to be clear.
It seems that the MAC addresses of switches are either attached to a port or to a VLAN.
In the case of a MAC address is attached to a VLAN, it is in fact attached to all ports that participate to the VLAN.
For example, if the management port is declared in VLAN #46, and if we assign only ports #3, #11 to the VLAN #46, we can manage the switch through the ports #3 and #11, and not through the other ports.
In this case, the MAC frames that include an IP datagram for the switch management have always the same MAC-DA address, whatever the port #3 or the port #11 these MAC frames are entering.
Is i correct?
Have you some comments?
Best regards,
Michel
Giuseppe Larosa
Hello Michel,
your understanding is correct, because the destination MAC address is that associated to SVI L3 interface Vlan46 in your example.
On the other hand, STP BPDU frames originated at port #3 and port #11 will be sourced with a different source MAC address the one associated to the specific L2 port. These MAC addresses belong to the MAC address ranges that in a modular switch can be seen in the output of show module.
It is likely in most platforms that all SVI interfaces defined on the switch will use the same MAC address.
In some cases where for example a FWSM firewall module is installed in a C6500 and it is used as a transparent firewall, to achieve communication between different SVIs on different VRFs  the MAC address used has to be differentiated.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Michel,
Hope to help
Giuseppe
Hello Giuseppe,
Thanks for this reply
So, in this case : Vlan46 <=> A specific MAC address <=> A specific IP address
It is exactly why I wanted to write this post, to clarify this opposition (...probably simple). There is at least a reason: the BPDU connectivity is a link segment connectivity that cannot go through the matrix switching of a bridge.
Thanks fo your experience
I keep that in memory
Best regards,
Michel
