maintaining clock settings on a 2950 switch?
ocicat002
I have set up external NTP synchronization on a 2950 switch which works fine while the switch is powered on. However if the switch is cycled with a "reload" command, the time established is way off once the switch comes back up. Is this the expected behaviour?
Thanks.
Jon Marshall
This is expected behaviour because the 2950 does not have a hardware clock which can keep the time between reboots. As long as your switch is resynching it's time via NTP it is nothing to worry about.
Jon
Jon Marshall
Jon
Thanks for confirming! I hadn't found this in the documentation yet.
BTW:
Also sometimes difficult finding mention whether the hardware supports an on-board calendar. I've found using the ntp update-calendar both often a fast method to help in determining this, and a great way to keep the calendar accurate across reboots/reloads (if you're using NTP).
