Major upgrade on 6880 VSS
KevinMuller
Hello guys,
I'm planning to do an upgrade of a pair of 6880X in VSS (no IA) with a major gap between releases : 15.1(2) to 15.4(1).
I understand that ISSU process is not possible, so do you know any other way of doing the upgrade to limit the network downtime? I think the only way is to modifiy the "boot system ..." value and reload both chassis?
Kevin
Reza Sharifi
Hi Kevin,
You need a maintenance window to do this as you need to reboot both chassis.
1-Load the new IOS to both primary and stand-by switches.
2-change the boot variable to point to the the new IOS.
3-Save config.
4-Verify boot variable (show bootvar).
5-Reload both chassis ( redundancy reload shelf )
6-When both switches back online, verify that the new image is installed, verify connectivity, verify routing, switching, etc...
Reza Sharifi
Hi Kevin,
3-Save config.
Hi Reza,
Thanks a lot for your solution, I will follow the steps during maintenance window.
Kevin
Hi Kevin,
Glad to help and good luck!
Reza
