Management VLAN up
andresmardones
Frequent Visitor
Frequent Visitor
How do I keep the management VLAN up without any device connected?
Do I need a loopback interface?
I'm using a Catalyst 3560 switch.
Thanks in advance.
Richard Burts
Andres
To keep a VLAN active it should have at least 1 port connected to a device or should have an active trunk. You have not given us any information about what the 3560 connects to. Is it possible to configure a port on the 3560 as a trunk and include the VLAN in the trunk?
Rick
Rick
Richard Burts
Andres
Rick
Rick
Rick,
I understand, it is clear. Yes, it is possible to include the management VLAN in a trunk.
Many thanks Rick!
Regards.
Andres.
