Management VLAN
tomfree_leo
Hi Netpro
I got cisco 3550 as backbone Switch ; edge switches connects to 3550 on Fiber
In all we got 5 switches and would increase more shortly, I want to have all switches on management vlan
I did the following but doesnt work
[3550]
Vlan 1
description users
Vlan 2
description managment vlan
ip address 192.168.100.1 255.255.255.0
int gi0/0
switchport trunk encap dot1q
switchport mode trunk
description connected to SW1
SW1 - 2960
int gi0/0
int vlan2
ip address 192.168.100.2 255.255.255.0
ip default-gateway 192.168.100.1
On SW1 with VLAN 1 ip address 192.168.1.100/24 is working ok
M i missing any more config to move all switches to managment VLAN
6 Replies 6
Jon Marshall
tomfree_leo wrote:
Hi Netpro
[3550]
Vlan 1
description users
Vlan 2
int gi0/0
SW1 - 2960
int gi0/0
int vlan2
Tom
No that should do it.
Can you post -
1) "sh ip int brief" from bith switches
2) "sh vlan" from both switches
3) "sh int trunk" from both switches
Jonj
I see VLAN2 cannot be seen on 2960
its a server and client setup, i feel need to shut and no shut the trunk to get vlan database updated.
Any cisco document with recommendation on configuring Management VLAN
Can someone help to understand what is native VLAN Vs Managment VLAN
Tom
Couple of things.
Yes you need vlan 2 in the output of "sh vlan" on the 2960. Check the revision numbers on the VTP server and client.
Native vlan is simply the vlan that is untagged on a trunk link. The native vlan should not be the management vlan and it should not be a vlan with any ports allocated to it. The native vlan doesn't need a L3 interface either.
Jon
A native vlan is the untagged vlan on an 802.1q trunked switchport.Basically if a switch receives untagged frames on a trunkport, they are assumed to be part of the vlan that are designated on the switchport as the native vlan.When the switch on the other side of the trunk receives a frame that does not have an 802.1Q header, the receiving switch knows that the frame is part of the native VLAN.
Hope to help
Ganesh.H
The management VLAN is simply a VLAN that is configured with a L3 interface and is used for to manage the switch via telnet/ssh. Best practices recommend seperating your management traffic from the standard user/data traffic. For my company however, adding and having to track another subnet at each of my branch offices would be a nightmare so we keep management traffic in the data VLAN.
