Map Network
AngeloCisco
Hi all,
for a project I have to go to various locations of a company to make a mapping of the network.
I wonder, based on your experience, if there software that scans the network, and maps all the different devices, with ip, machine name, type of device, type of links and more information.
I find only software:
Network Topology Mapper - Topology Mapping Software | SolarWinds
Can you recommend some software?
Many thanks in advance
Angelo
Reza Sharifi
SolarWinds NPM will discover all devices, their IPs, OS, number of ports, etc...
From that, you can create a diagram of all devices.
Many Thanks,
other software to suggest for this activity?
Have a look at this list. NPM is at the top.
https://www.pcwdld.com/best-network-monitoring-tools-and-software
