Massive output queue drops 6509
andreas.plaul
Level 2
Level 2
Dear all,
we replaced our existing 3750 stack (4 3750's with GE connections) with a 6509.
Since then I see massive output packet drops on interfaces. I checked the forum and many people are talking about line cards (WS-X6548-GE-TX), which might be the reason. But the load rarely goes over 100Mbits on those interfaces and I still see drops in the range of 10% on the overall traffic.
For testing I removed all QoS config from the interfaces, but it had no positive effect. I am really looking for help on this.
Please find below the needed information:
Mod Ports Card Type Model
1 24 CEF720 24 port 1000mb SFP WS-X6724-SFP
2 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX
3 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX
4 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
* GigabitEthernet3/24 0 0 0 277914 250000 63 81000 83 0
* GigabitEthernet3/25 0 0 0 50710155 0 0 0 0 0
* GigabitEthernet3/26 0 0 0 50710155 0 0 1000 2 0
* GigabitEthernet3/27 0 0 0 50710155 0 0 1000 2 0
* GigabitEthernet3/28 0 0 0 50710155 2000 2 3000 4 0
* GigabitEthernet3/29 0 0 0 50710155 0 0 0 0 0
* GigabitEthernet3/30 0 0 0 50710155 1000 1 2000 3 0
* GigabitEthernet3/31 0 0 0 50710155 0 0 0 0 0
* GigabitEthernet3/32 0 0 0 50710155 380000 158 535000 164 0
* GigabitEthernet3/33 0 0 0 223739947 2000 0 54000 4 0
* GigabitEthernet3/34 0 0 0 223739947 0 0 1000 2 0
* GigabitEthernet3/35 0 0 0 223739947 3976000 513 3250000 467 0
* GigabitEthernet3/36 0 0 0 223739947 15000 13 390000 31 0
* GigabitEthernet3/37 0 0 0 223739947 131000 58 82000 67 0
* GigabitEthernet3/38 0 0 0 223739947 0 0 13000 21 0
GigabitEthernet3/39 0 0 0 223739947 0 0 0 0 0
GigabitEthernet3/40 0 0 0 223739947 0 0 0 0 0
interface GigabitEthernet3/35
switchport
switchport access vlan XXX
switchport mode access
switchport voice vlan XXX
no ip address
wrr-queue bandwidth 30 70
wrr-queue queue-limit 40 30
wrr-queue random-detect min-threshold 1 40 80
wrr-queue random-detect min-threshold 2 70 80
wrr-queue random-detect max-threshold 1 80 100
wrr-queue random-detect max-threshold 2 80 100
wrr-queue cos-map 1 1 1
wrr-queue cos-map 1 2 0
wrr-queue cos-map 2 1 2 3 4
wrr-queue cos-map 2 2 6 7
mls qos trust cos
interface GigabitEthernet3/36
switchport
no ip address
mls qos trust cos
spanning-tree portfast
5 Replies 5
Giuseppe Larosa
Hello Andreas,
have you seen if these drops are real and are affecting real traffic or are simply figures in the show?
This is to understand if there is a big impact or it can be seen as cosmetic, for example I see that several ports share the exact some counter value that it is unlike.
Hope to help
Giuseppe
stephenshaw
Level 6
Level 6
Hi Andreas,
this may be what you are experiencing ...
the WS-X6548-GE-TX is designed to "share" 1Gig for groups of 8 ports - this is referred as an 8:1 oversubscription.
i.e. if you load up ports 1 to 8 with heavily utilized servers, this will cause drops.
Cisco recommends using the newer WS-X6748-GE-TX modules which use a matrix to achieve far better "over-subscription" ratios depending upon specific placements within the chassis. This of, course means extra cost and requires a specific IOS code on the Sup 720.
Now, if this route is not cost effective for your company, you can try configuring traffic flow control on indivdual ports/servers and/or ensure the heavy hitting servers are not on a common ASIC (which controls each indvidual group of 8 ports).
Many companies, including mine, still use the WS-X6548-GE-TX for server connections and we found using flow control for specific servers helped prevent the drops.
HTH,
Steve
Hello Steve,
I see that drops are equal for ports 32-38 in the output this is caused by this port sharing a single ASIC chip!
We have similar behaviour in C4500 4548 linecards
Thanks for your info
Best Regards
Giuseppe
Hi Guiseppe,
the matrix design on the newer line card can give up to 40G per port (pending placement in the 6509 - E chassis). However, nothing less than 20G is provisioned which takes the 8:1 oversubscription down to around 2.1:1 oversubscription - far better but is chassis specific & IOS specific. i.e. probably worth the investment for a net new Data Centre switch but may not be worth upgrading an existing one.
I'm on the hunt for the Cisco link and will post it if I can find it.
regards,
Steve
I found the reference link:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801751d7.shtml#topic3
Details on the new line card and the use of a fabric matrix were done via a direct technical session with Cisco and I'm not aware of any links that detail how the new line card functions.
I would recommend that if anyone is considering new 6509-E switches for a Data Centre environment that you arrange a technical session with your Cisco reps. to determine the specific requirements and cost.
Steve
