Max. MTU on a Jumbo Frame Trunk Interface
hakan.topcu
Hi all,
assumed I have configured a Gigabit Interface with the max. possible MTU of 9216 byte (incl. L2 Header and Trailer)
interface g1/1
mtu 9198
or
system mtu jumbo 9198
Cisco wrote the following:
"... When you enable a port for 802.1q trunking, the switch automatically assumes that an extra four bytes of data are appended on, and increment the frame size of the L2 packet. ..."
Source: Jumbo/Giant Frame Support on Catalyst Switches Configuration Example
http://www.cisco.com/en/US/customer/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml
If I configure the above-named interface as a dot1q trunk, does this raise the MTU for additional 4 bytes to 9220 byte???
Thanks!
Hakan
0 Replies 0
