Maximum memory size for 2800 series routers
astanislaus
Level 2
Level 2
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/ps5882/product_data_sheet0900aecd8016fa68_ps5854_Products_Data_Sheet.html
As per this link 2811 routers support 256 MB CF. I know the P/N for 128 CF and it is MEM2800-128CF. What is the Cisco P/N for 256 MB CF? Is it MEM2800-256CF.
Is there a link on CCO giving this P/N MEM2800-256CF for our 2811 routers.
At the moment we are using 1 GB CF from a third party and we are having intermittent problem adding files to this CF after 80 MB only have been used out of 1 GB CF. We get "Failed Sector Write" error
Router#copy tftp flash:
Address or name of remote host []? 172.31.135.98 Source filename []? c2800nm-spservicesk9-mz.124-15.T5.bin
Destination filename [c2800nm-spservicesk9-mz.124-15.T5.bin]?
Accessing tftp://172.31.135.98/c2800nm-spservicesk9-mz.124-15.T5.bin...
Loading c2800nm-spservicesk9-mz.124-15.T5.bin from 172.31.135.98 (via FastEthernet0/0): !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
%Error writing flash:/c2800nm-spservicesk9-mz.124-15.T5.bin (Failed Sector Write)
I need to buy some Cisco 256 MB CF and try:
Also see attachment
Hi Alphonse,
I did a quick search in the price list and found that MEM2800-256CF= (256MB CF for the Cisco 2800 Series) part number is available for ordering.
However there is no document available on CCO.
I'll suggest, you get in touch with your partner/distributor and ask for a 256MB CF for your router.
-> Sushil
jaregalado
these are the part numbers of CF cards available for 28xx series routers:
MEM2800-128CF= 128MB CF for the Cisco 2800 Series USD 700.00
MEM2800-256CF= 256MB CF for the Cisco 2800 Series USD 900.00
MEM2800-64CF= 64MB CF for the Cisco 2800 Series USD 400.00
You must stick to Cisco branded CFs only, anything else is not supported by Cisco.
Regards.
Jsmie,
Thsmkd for the info.
My customer is using 1 GB flash from Kingston.
He has problems loading higher version of IOS files into this flash and if loaded fails to boot, etc.
