maximum MST instances
kjbarrass
We have a mix of Cisco 6500s and 4500s all running MST although the 4500 are running pre-standards MST. Looking at the link http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/mst.html the maximim MST instances per region is 65 is this the case for standards and pre standards based MST on the above platforms also does the 4500/6500 have hardware/platform specific limitations on the number of MST instances.
Kind Regards
Kev
kjbarrass
done some more digging and found the below:
MST instances on 6500 12.2SX
Max is 65 instances per region
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/spantree.html
this document states there are some IOS releases only supporting 16 instances
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a00807b075f.shtml
The below link states that 4500 on train 12.1(19)EW only supports 15 0-15 MST instances.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.1/19ew/configuration/guide/mst.html
