Maximum SPAN sessions on a 3750 switch
SlipperyPete
We're running a switched LAN environment, made up mostly of 3750 switches (and switch stacks). One one of our "core" switch stacks, we're running two different SPAN sessions for IDS, etc. I tried to add a third for another appliance, but the IOS says "Platform can support a maximum of 2 source sessions". Can anyone confirm this is the case? Is that the absolute limit for monitoring (SPAN) sessions on a 3750 switch? I just want to confirm this before I tell my boss that we have to get a different platform if we want more SPAN sessions.
Thanks.
rahurao
Hi ,
The IOS is displaying the correct information.
The Local SPAN session limit is 2 but you can use RSPAN configuration for the same.
These are the local SPAN and RSPAN session limits:
Total Sessions per Switch
Local SPAN Sessions
RSPAN Source Sessions
RSPAN Destination Sessions
66
2 (ingress or egress or both)
1 ingress
1 (ingress or egress or both)
1 or 2 egress
Local SPAN and RSPAN Source and Destination Limits
These are the local SPAN and RSPAN source and destination limits:
Sources and Destinations
Local SPAN Sessions
Egress sources
1 (0 with a remote SPAN source session configured)
1 (0 with a local SPAN egress source session configured)
1 RSPAN VLAN
Ingress sources
64
64
Destinations per session
64
1 RSPAN VLAN
64
Rahul
