Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Unless one or both ends support auto-MDI (and it's enabled), you'll need a cross over cable (as noted by Lonestar). If auto-MDI is active, then as Reza notes, a strait through cable should work too.
Learn, share, save
