ME 3400 and VTP
narainarun
Hi All,
We purchased ME 3400 switch and trying to implement it. But its quite surprising in the ME3400 configuration guide that the switch does not support VTP. When I checked in Feature navigator under feature "VTP" i could see ME3400 supports VTP. But when i get into CLI of ME3400, i am not getting any option of configuring VTP. I could see in some sites VMPS is supported in ME3400.
I would like to confirm the following:
1. Does VTP support present in ME3400 or not? If not, what would be the reason that it is not included in ME3400.
2. If not what is the alternative.
Network is already running VTP of around 30 switches.
thanks
Arun
burleyman
Level 8
Level 8
Arun,
VTP is not supported on the ME 3400, not sure why.
Here is a link that might help in figuring out what you could do.
http://www.cisco.com/en/US/docs/switches/metro/me3400/software/release/12.2_55_se/configuration/guide/ME3400_scg.html
Mike
The most interesting is that in feature navigator VTP2 appears as supported feature.
FN is wrong unfortunately.
My suggestion is to consider it as the last source of info. You should to prefer release notes, data sheets and configuration guides first.
