ME3400 Intervlan Routing - NOOB
scottym1139
Hi Folks,
I'm cutting my teeth on cisco and am having some issues with intervlan routing. I have followed the vids and manuals but just can seem to get this working. I have the following network lab set up.
Vlan 10 = 10.70.1.9/24
Vlan 20 = 192.168.0.1/24
ME2400 firmware
ROM: Bootstrap program is ME340x boot loader
BOOTLDR: ME340x Boot Loader (ME340x-HBOOT-M) Version 12.2(35r)SE3, RELEASE SOFTWARE (fc1)
Switch uptime is 7 minutes
System image file is "flash:me340x-metroipaccessk9-mz.122-44.SE1.bin"
Running config :-
witch#sh run
Building configuration...
Current configuration : 2562 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
crypto pki trustpoint TP-self-signed-3933083008
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3933083008
revocation-check none
rsakeypair TP-self-signed-3933083008
crypto pki certificate chain TP-self-signed-3933083008
certificate self-signed 01
  3082023F 308201A8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33393333 30383330 3038301E 170D3933 30333031 30303030
  35365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39333330
  38333030 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D4AE C4AB8FB8 32426775 6D022437 2C5C113E A4D7370A 32EC5C9A B1612289
  8A0D1DFA 317B73BF 8744A43F 46ED8A40 EC3D69DB F574A45F B53152BC C3D8A037
  53AD79AD F51CC7B2 34C7D771 E3D4E5FD 73F2246C 4B56C50B D57D5B27 9B9584C8
  CF733E77 4256956F 5B05E61E 64693414 BE3DBBB4 BC8051BE 7576FA01 910A1CA0
  03910203 010001A3 67306530 0F060355 1D130101 FF040530 030101FF 30120603
  551D1104 0B300982 07537769 7463682E 301F0603 551D2304 18301680 14E6CCBE
  104CE6DC DFDC0B1D 6BBF2400 B09C3BCB 1A301D06 03551D0E 04160414 E6CCBE10
  4CE6DCDF DC0B1D6B BF2400B0 9C3BCB1A 300D0609 2A864886 F70D0101 04050003
  8181009E E78DF428 A9DCA43A 692D95F7 929CA086 D4927A65 EF2CCC6E B50D72D3
  20B8F7AF C063179C F80E7B73 23FF6B98 B73E236A 95024023 37294CF2 34FDD024
--More--
vlan internal allocation policy ascending
vlan 10,20
interface GigabitEthernet0/1
port-type nni
switchport access vlan 10
interface GigabitEthernet0/2
port-type nni
switchport access vlan 20
interface GigabitEthernet0/3
port-type nni
interface GigabitEthernet0/4
port-type nni
interface Vlan1
no ip address
interface Vlan10
ip address 10.70.1.9 255.255.255.0
interface Vlan20
ip address 192.168.0.1 255.255.255.0
no ip http server
ip http secure-server
ip classless
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch#
I can ping from a host on 192.168.0.X to 10.70.1.9 but can ping no further and i can ping from a host on 10.70.1.X to 192.168.0.1 but can ping no further.
witch#
Switch#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/24 is subnetted, 1 subnets
C       10.70.1.0 is directly connected, Vlan10
C    192.168.0.0/24 is directly connected, Vlan20
Switch#sh mac address-table
          Mac Address Table
Vlan    Mac Address       Type        Ports
All    0100.0ccc.cccc    STATIC      CPU
All    0100.0ccc.cccd    STATIC      CPU
All    0180.c200.0000    STATIC      CPU
All    0180.c200.0001    STATIC      CPU
All    0180.c200.0002    STATIC      CPU
All    0180.c200.0003    STATIC      CPU
All    0180.c200.0004    STATIC      CPU
All    0180.c200.0005    STATIC      CPU
All    0180.c200.0006    STATIC      CPU
All    0180.c200.0007    STATIC      CPU
All    0180.c200.0008    STATIC      CPU
All    0180.c200.0009    STATIC      CPU
All    0180.c200.000a    STATIC      CPU
All    0180.c200.000b    STATIC      CPU
All    0180.c200.000c    STATIC      CPU
All    0180.c200.000d    STATIC      CPU
All    0180.c200.000e    STATIC      CPU
All    0180.c200.000f    STATIC      CPU
All    0180.c200.0010    STATIC      CPU
All    ffff.ffff.ffff    STATIC      CPU
  20    00a0.244e.1f26    DYNAMIC     Gi0/2      (HOST ON 192.168.0.5)
  10    0025.b36e.383a    DYNAMIC     Gi0/1     (HOST ON 10.70.1.5)
Total Mac Addresses for this criterion: 22
Can anyone help me ?
Thanks in advance.
Giuseppe Larosa
Hello Scott,
you should consider that your hosts may have a SW FW running on them.
the fact that each host can ping the SVI of the other vlan is a proof that inter-vlan routing is working correcty.
Host to host communication involves possible network protection on end user devices.
For example windows running PCs show this kind of behaviour.
Hope to help
Giuseppe
Hi Giuseppe,
I can ping both hosts from the switch
Switch>en
Switch#ping 10.70.1.5
Sending 5, 100-byte ICMP Echos to 10.70.1.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/9 ms
Switch#ping 192.168.0.5
Sending 5, 100-byte ICMP Echos to 192.168.0.5, timeout is 2 seconds:
Success
But cannot ping through the switch to each other. No SF FW in the picture...both hosts are vanilla installs with no FW or AV installed totally open machines. Weird ?
Scott
Hi Giuseppe,
You were right, out Symantec has the Smart firewall activated and was blocking pings from foreign networks (Was running hidden). I had the windows firewall switched off though.
Thanks for all your help.
Scott
Hello Scott,
I'm glad to know that my suggestion was helpful.
Best Regards
Giuseppe
