me3600x boot issue
richard.bailey
I have been trying to recover a me3600x switch, see below:
switch: dir
List of filesystems currently registered:
                  bs[0]: (read-only)
              ucode1[2]: (read-write)
              xmodem[3]: (read-only)
                null[4]: (read-write)
                tftp[5]: (read-only)
switch: Flash_init
Unknown cmd: Flash_init
switch: flash_init
Initializing Flash...
...The flash is already initialized.
switch: mgmt_init
The "MAC_ADDR" environment variable is not set.
Can not execute command: MAC_ADDR is not available yet.
usage: mgmt_init
switch: set IP_ADDR 10.1.1.2/255.255.255.0
bs_open[1]: Unable to erase boot_block 0
vb:: I/O error
Any ideas would be greatly received.
Leo Laohoo
Post the output to the command "dir flash:".
switch: dir flash:
unable to stat flash:/: no such device
You've got two choices:
1.  RMA the switch.  The Flash memory is either dislodged or faulty;
2.  Open the lid, look for any detachable DIMM, eject it, clean it and reinsert back to the slot.
I just recovered a bricked ME3600X last week.  I just put my image on an SD card and used the SD card slot on the front.  I did learn though, that it won't detect your SD card after boot.  You have to have your SD card in the ME3600X then boot it.  Hope this helps.
