Media converter speed problem !
Murad*
Level 5
Level 5
Hi every one
i have two switches and i connected together with Fiber optic cable , but there is a small problem , because i didn't have fiber place in one of this Cisco switch , i forced to use Media converter ( that explain in the picture ) , so the link between this switch working normally but Suddenly it didn't work !
i tried to change speed under interface and i change it to ( speed nonegotiate ) and the link return to work normally again !
and so on , some times work with this command and sometimes work without it !
can any one explain this case !!
Very Thanks
M02@rt37
Hi @Murad*
What is the brand of your media converter?
Have you got small DIP switch on this media converter on the back panel.
The DIP switches are used to manually configure the operating characteristics of the RJ-45 twisted-pair port such as port speed, duplex mode, Auto-Negotiation.
Best regards
