Memory and CPU usage thresholds?
ppucci
Community Member
Hi there!
I would like to know if there is a rule of thumb for whether a device (switch or router) should be upgraded (or replaced) after it reaches a certain CPU or memory threshold.
We are planing the replacement of several devices and we were thinking what would be a reasonable threshold cut for CPU and Memory (both isolated and together).
Persio
dsweeny
Level 6
Level 6
The memory upgrade is taken care by upgrading the size of NVRAM or by upgrading the version of Router or switch.
