Memory Exceeds Warning Level
jrdejesus
Would like to inquire the issue we have in our ISR4451-X/K9. The current OS is isr4400-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin.
PCGRT2101#         sh logg | i PLATFORM
045639: Jul 10 02:37:41.919 UTC: %PLATFORM-4-ELEMENT_WARNING:smand:  RP/0: Committed Memory value 93% exceeds warning level 90%
045671: Jul 10 02:47:51.936 UTC: %PLATFORM-4-ELEMENT_WARNING:smand:  RP/0: Committed Memory value 93% exceeds warning level 90%
045678: Jul 10 02:58:01.968 UTC: %PLATFORM-4-ELEMENT_WARNING:smand:  RP/0: Committed Memory value 93% exceeds warning level 90%
045684: Jul 10 03:08:02.013 UTC: %PLATFORM-4-ELEMENT_WARNING:smand:  RP/0: Committed Memory value 93% exceeds warning level 90%
045689: Jul 10 03:18:12.086 UTC: %PLATFORM-4-ELEMENT_WARNING:smand:  RP/0: Committed Memory value 93% exceeds warning level 90%
045694: Jul 10 03:28:22.136 UTC: %PLATFORM-4-ELEMENT_WARNING:smand:  RP/0: Committed Memory value 93% exceeds warning level 90%
045700: Jul 10 03:38:32.148 UTC: %PLATFORM-4-ELEMENT_WARNING:smand:  RP/0: Committed Memory value 93% exceeds warning level 90%
045705: Jul 10 03:48:42.185 UTC: %PLATFORM-4-ELEMENT_WARNING:smand:  RP/0: Committed Memory value 93% exceeds warning level 90%
045711: Jul 10 03:58:52.232 UTC: %PLATFORM-4-ELEMENT_WARNING:smand:  RP/0: Committed Memory value 93% exceeds warning level 90%
045717: Jul 10 04:09:02.277 UTC: %PLATFORM-4-ELEMENT_WARNING:smand:  RP/0: Committed Memory value 93% exceeds warning level 90%
045724: Jul 10 04:19:12.306 UTC: %PLATFORM-4-ELEMENT_WARNING:smand:  RP/0: Committed Memory value 93% exceeds warning level 90%
045730: Jul 10 04:29:22.404 UTC: %PLATFORM-4-ELEMENT_WARNING:smand:  RP/0: Committed Memory value 93% exceeds warning level 90%
PCGRT2101#
PCGRT2101#show platform resources
**State Acronym: H - Healthy, W - Warning, C - Critical
Resource                 Usage                 Max             Warning         Critical        State
RP0 (ok, active)        C
 Control Processor       20.00%                100%            90%             95%             H
  DRAM                   3848MB(99%)           3872MB          90%             95%             C
ESP0(ok, active)        H
 QFP        H
  DRAM                   1653163KB(78%)        2097152KB       80%             90%             H
  IRAM                   0KB(0%)               0KB             80%             90%             H
PCGRT2101#
5 Replies 5
Philip D'Ath
Does the below command show anything interesting?
show processes memory sorted allocated
Hi Philip,
Thanks for the reply. Below is the output of show processes memory sorted. Thanks
PCGRT2101#show process memory sorted
Processor Pool Total: 1688346960 Used: 1414656896 Free: 273690064
lsmpi_io Pool Total: 6295128 Used: 6294296 Free: 832
PID TTY Allocated Freed Holding Getbufs Retbufs Process
623 0 5038194376 2433095640 863919712 0 0 BGP Router
0 0 634703960 340859896 272617720 0 0 *Init*
300 0 1484327248 2166903128 231054728 12250980 0 IP RIB Update
79 0 67744984 14104 7594632 0 0 IOSD ipc task
165 0 6997424 164848 4798656 0 0 CWAN OIR Handler
481 0 3887216 5160 3923920 799092 0 EEM ED Syslog
0 0 928719096 923135032 3843528 8177103 0 *Dead*
1 0 2913264 900024 2043104 0 0 Chunk Manager
507 0 1444096 27776 1446184 0 0 EEM Server
6 0 525680 21808 461392 0 0 RF Slave Main Th
0 0 0 0 461136 0 0 *MallocLite*
482 0 375536 5160 412240 67468 0 EEM ED Generic
463 0 299792 1136 352520 0 0 Crypto IKEv2
512 0 619837960 362552328 251640 0 0 BGP Task
202 0 614432 339208 250624 0 0 mDNS
306 0 1808 0 247808 0 0 COPS
508 0 260832 183472 224336 0 0 Call Home proces
607 0 167680 448 221096 0 0 MRIB Process
10 0 2189109176 2198317832 215224 2093222853 2095142581 Pool Manager
452 0 1330520 1178224 196128 0 0 Crypto CA
198 0 139704 72032 186064 0 0 IP ARP Adjacency
3 866 8791368 8648024 184208 0 0 SSH Process
363 0 153824 448 183240 0 0 RUDPV1 Main Proc
614 0 124384 0 178248 0 0 IP SLAs Responde
175 0 228465120 415056992 173128 0 0 BGP I/O
367 0 140336 0 170200 0 0 L2FIB Event Disp
15 0 9713993024 9713852816 170072 0 0 ARP Input
257 0 65632 0 167496 0 0 st_pw_oam
7 0 65632 0 167496 0 0 EDDRI_MAIN
613 0 122680 0 164544 0 0 IP SLAs Control
612 0 115752 576 157616 0 0 IP SLAs XOS Even
196 0 98736 0 152600 0 0 IPAM Manager
489 0 49496 2544 151472 0 0 LICENSE AGENT
395 0 1513592 1974848 146512 0 756 HSRP IPv4
497 0 167720 76680 144760 0 0 VLAN Manager
444 0 102848 0 132712 0 0 MMA DB TIMER
302 0 98496 8288 132072 0 0 IP Connected Rou
214 867 1746096 1663048 130976 0 0 SSH Process
408 0 98776 0 128640 0 0 AAA HA cleanup
445 0 99192 448 128608 0 0 Timer Library
174 0 98736 0 128600 0 0 ACCT Periodic Pr
368 0 65528 0 119392 0 0 ATM HA
617 0 4033775496 5988246296 114072 0 0 SNMP ENGINE
313 0 11904 0 113768 0 0 HTTP CORE
283 0 62984 5448 110280 0 0 CEF background p
364 0 1491640 1184216 110008 0 0 HSRP Common
237 0 2624 448 104040 0 0 Ethernet CFM
187 0 73016 528 102352 0 0 VRRS Main thread
616 0 1954487864 0 101864 0 0 PDU DISPATCHER
95 0 0 0 101864 0 0 RF CWAN HA Proce
471 0 0 0 101864 0 0 Crypto ACL
80 0 4640 4640 101864 0 0 IOSD chasfs task
314 0 67976 0 97840 0 0 DHCP SIP
199 0 68936 2872 95928 0 0 IP ARP Retry Age
294 0 54912 12896 95304 0 0 CEF: IPv4 proces
23 0 81624 16400 94656 0 0 Entity MIB API
468 0 41176 1736 94592 0 0 Crypto IKMP
427 0 56320 448 85736 0 0 HTTP Process
323 0 361064 326792 80912 0 0 static
535 0 26816 896 79784 0 0 RBM CORE
620 0 64766848 64756056 77936 0 0 SNMP Traps
68 0 329616 71152 74176 0 0 Net Background
168 0 43032 1064 70328 0 0 ACE event
333 0 104824 448 68328 0 0 SCTP Main Proces
230 0 38408 1392 66880 0 0 MKA
528 0 29376 5160 66080 0 0 EEM ED CRASH
492 0 10544 448 63960 0 0 ISG MIB jobs Man
261 0 8504 0 62368 0 0 IMA PROC
438 0 13134808 7313536 61208 0 0 TPLUS
301 0 37504 27304 60456 0 0 IP Background
532 0 5152 0 59016 0 0 udp_transport Se
621 0 108088 73080 58328 0 0 NTP
305 0 16877712 5529859712 58144 0 0 TCP Protocols
530 0 4413608 4410640 56832 0 0 Syslog
470 0 140088 70896 56720 0 0 IPSEC key engine
73 0 2568 0 56432 0 0 CTS CORE
455 0 2128 0 55992 0 0 PKI OCSP
527 0 19280 5160 55984 0 0 EEM ED DS
432 0 2432 448 55848 0 0 LDAP process
615 0 1427604504 1427599152 55568 0 0 IP SNMP
618 0 1936 448 55480 0 0 IP SNMPV6
511 0 15304 1776 55392 0 0 EEM Policy Direc
272 0 1696 448 55112 0 0 DTP Protocol
373 0 712 0 54688 0 0 MRIB RP Proxy
478 0 31296 6968 54576 0 0 DCM Core Thread
69 0 4272 3776 54360 0 0 IDB Work
381 0 456 0 54320 0 0 FRR Manager
461 0 896 448 54312 0 0 MMON PROCESS
284 0 408 0 54272 0 0 fib_fib_bfd_sb e
178 0 408 0 54272 0 0 CEF switching ba
296 0 728 7352 54272 0 0 Collection proce
297 0 2680 2272 54272 0 0 ADJ resolve proc
295 0 408 70800 54272 0 0 ADJ background
319 0 408 0 54272 0 0 MFIB Master back
606 0 1464235520 1464235360 54024 0 0 mdns Timer Proce
61 0 448 448 53992 0 0 XML Proxy Client
72 0 448 30120 53976 0 0 SXP CORE
21 0 0 0 53976 0 0 Policy Manager
122 0 0 0 53976 0 0 FMD HA IPC flow
480 0 0 0 53864 0 0 Test AAA Client
256 0 0 0 53864 0 0 MPLS Auto-Tunnel
255 0 0 0 53864 0 0 LSP Tunnel FRR
293 0 0 0 53864 0 0 Routing Topology
258 0 448 448 53864 0 0 ATM OAM Input
499 0 0 0 53864 0 0 IKEv2 FlexVPN Pr
259 0 448 448 53864 0 0 ATM OAM TIMER
467 0 448 2184 53864 0 0 Crypto IKE Dispa
466 0 0 0 53864 0 0 Crypto INT
247 0 448 448 53864 0 0 RG Faults Timer
260 0 448 448 53864 0 0 SSS Mobility mes
619 0 0 0 53864 0 0 SNMP ConfCopyPro
457 0 0 0 53864 0 0 encrypt proc
456 0 0 0 53864 0 0 PKI Revocation
279 0 0 0 53864 0 0 XDR receive
454 0 0 0 53864 0 0 Crypto PKI-Rev-P
453 0 448 448 53864 0 0 Crypto PKI-CRL
298 0 448 448 53864 0 0 Tunnel
451 0 0 0 53864 0 0 RSA background p
222 0 0 0 53864 0 0 SSS PM SHIM QOS
304 0 0 4481920 53864 0 0 TCP Timer
189 0 0 0 53864 0 0 IEDGE ACCT TIMER
70 0 448 448 53864 0 0 Logger
249 0 448 448 53864 0 0 RG Transport Tim
235 0 448 448 53864 0 0 Ethernet LMI
121 0 0 0 53864 0 0 Metadata HA
248 0 448 448 53864 0 0 RG Protocol Time
443 0 0 0 53864 0 0 MPLS Auto Mesh P
223 0 0 0 53864 0 0 LONG TO SHORT NA
125 0 0 0 53864 0 0 Crypto PKI-HA
155 0 0 0 53864 0 0 IPSec background
307 0 448 448 53864 0 0 NGCP SCHEDULER P
308 0 448 448 53864 0 0 STILE PERIODIC T
309 0 448 448 53864 0 0 UV AUTO CUSTOM P
205 0 448 448 53864 0 0 KRB5 AAA
315 0 448 448 53864 0 0 IP SIP Process
384 0 0 0 53864 0 0 LFD Label Block
133 0 0 0 53864 0 0 ACT2 Crypto Engi
337 0 448 448 53864 0 0 Auth Manager
383 0 0 0 53864 0 0 Path set broker
316 0 448 448 53864 0 0 IP Inband Sessio
436 0 1552 1552 53864 0 0 LOCAL AAA
138 0 0 0 53864 0 0 ASYNC Input
433 0 0 0 53864 0 0 Opaque Database
379 0 448 448 53864 0 0 MCPRP RG Timer
219 0 0 0 53864 0 0 SSS Policy Manag
425 0 0 0 53864 0 0 SSL background p
218 0 0 0 53864 0 0 SSS Manager
217 0 448 448 53864 0 0 SSM connection m
376 0 0 0 53864 0 0 RG If-Mgr Timer
54 0 448 448 53864 0 0 Dialer event
51 0 0 0 53864 0 0 License IPC serv
148 0 0 0 53864 0 0 MCP RP autovc pr
213 0 448 448 53864 0 0 PPP IP Route
150 0 0 0 53864 0 0 BFD HW EVENT
151 0 0 0 53864 0 0 BFD IPV6 ADDR CH
50 0 0 0 53864 0 0 License IPC stat
388 0 0 0 53864 0 0 RSVP HA Services
210 0 0 0 53864 0 0 DM Proc
336 0 448 448 53864 0 0 Flow Exporter Pa
192 0 448 448 53864 0 0 IP Static Sessio
330 0 448 448 53864 0 0 X.25 Background
193 0 448 448 53864 0 0 DVLAN Config Pro
334 0 0 0 53864 0 0 VPDN call manage
335 0 448 672 53864 0 0 Flow Exporter Ti
352 0 0 0 53864 0 0 Ethernet PM Moni
377 0 448 448 53864 0 0 RG Media Timer
200 0 1143299968 8448 53864 0 0 IP Input
197 0 448 448 53864 0 0 IPAM Events
135 0 16008 47168 52832 0 0 EEM ED ND
515 0 15400 5160 52104 0 0 EEM ED Interface
485 0 15128 5728 51832 0 0 EEM ED Resource
126 0 36728 59832 50992 0 0 RF Master Main T
519 0 14616 5224 50760 0 0 EEM ED RF
483 0 13960 5216 50608 0 0 EEM ED Track
523 0 13808 5160 50512 0 0 EEM ED Timer
534 0 13592 5160 50432 0 0 EEM ED RPC
484 0 13696 5160 50400 0 0 EEM ED Routing
522 0 13696 5160 50400 0 0 EEM ED SNMP Noti
516 0 13632 5160 50336 0 0 EEM ED IOSWD
529 0 13504 5160 50320 0 0 EM ED GOLD
525 0 13504 5160 50208 0 0 EEM ED Config
517 0 13504 5160 50208 0 0 EEM ED None
526 0 13504 5160 50208 0 0 EEM ED Env
540 0 13504 5160 50208 0 0 EEM ED Ipsla
514 0 13504 5160 50208 0 0 EEM ED Counter
524 0 13504 5160 50208 0 0 EEM ED Test
513 0 13504 5160 50208 0 0 EEM ED CLI
521 0 13504 5160 50208 0 0 EEM ED SNMP Obje
518 0 13504 5160 50208 0 0 EEM ED OIR
520 0 13504 5160 50208 0 0 EEM ED SNMP
117 0 4824650568 306472760 48096 0 0 IOSXE-RP Punt Se
439 0 9744 1032 46576 0 0 EST Client
173 0 16632 0 46496 0 0 AAA ACCT Proc
486 0 187922584 187906640 45808 0 0 Syslog Traps
312 0 20672 5608 44928 0 0 SR CapMan Proces
414 0 14440 0 44304 0 0 CEM PROC
503 0 17832 3520 43560 0 0 DCM snmp dp Thre
320 0 1864 448 43280 0 0 MVPN Mgr Process
184 0 13408 0 43272 0 0 TRACK Main threa
321 0 896 448 42312 0 0 Multicast Offloa
292 0 408 0 42272 0 0 Tunnel FIB
487 0 0 0 41976 0 0 Network Synchron
285 0 0 0 41864 0 0 IP IRDP
351 0 448 448 41864 0 0 Ethernet PM Soft
81 0 0 0 41864 0 0 REDUNDANCY FSM
90 0 0 0 41864 0 0 CONSOLE helper p
350 0 0 0 41864 0 0 Ethernet PM Proc
353 0 0 0 41864 0 0 Ethernet Datapla
338 0 0 0 41864 0 0 EPM MAIN PROCESS
206 0 0 831416168 41864 0 0 BGP Scanner
327 0 0 0 41864 0 0 IPv6 Static Hand
326 0 0 0 41864 0 0 IPv6 RIB Event H
325 0 0 0 41864 0 0 IPv6 RIB Cleanup
274 0 448 448 41864 0 0 802.1x Accountin
324 0 448 448 41864 0 0 App Route Proces
332 0 30110800 30110800 41864 0 0 QoS stats proces
188 0 0 0 41864 0 0 HQF TARGET DYNAM
236 0 448 448 41864 0 0 Ethernet OAM Pro
27 0 448 448 41864 0 0 ATM AutoVC Perio
441 0 16800 16800 41864 0 0 DynCmd Package P
419 0 0 0 41864 0 0 BGP Consistency
475 0 0 0 41864 0 0 Licensing MIB pr
449 0 0 0 41864 0 0 QOS PERUSER
469 0 0 0 41864 0 0 IPSEC manual key
437 0 0 0 41864 0 0 BGP Event
128 0 752 0 41864 0 0 BGP Scheduler
460 0 0 0 41864 0 0 SEGMENT ROUTING
131 0 0 0 41864 0 0 Per-Second Jobs
115 0 448 448 41864 0 0 SISF HA Process
531 0 0 0 41864 0 0 BGP BMP Server
286 0 11752 0 41616 0 0 LSD HA Proc
505 0 16920 20536 41512 0 0 Bulkstat-Client
355 0 10880 440 40448 0 0 IGMPSN L2MCM
592 0 10096 0 39960 0 0 IPC ISSU Version
545 0 10096 0 39960 0 0 IPC ISSU Version
98 0 10096 0 39960 0 0 ANCP HA IPC flow
477 0 9624 464 39160 0 0 dcm_cli_provider
157 0 8688 0 38448 0 0 SSH Event handle
608 0 9096 528 38432 0 0 EEM Helper Threa
76 0 11688 0 38368 0 0 IF-MGR event pro
391 0 7176 3480 37040 0 0 VPWS Thread
385 0 7056 0 36920 0 0 LDP HA
506 0 6856 464 35992 0 0 dcm_expression_p
9 0 6240 448 35656 0 0 Check heaps
504 0 6256 464 35504 0 0 snmp dcm ma shim
130 0 5632 0 35496 0 0 Per-minute Jobs
476 0 4464 0 34328 0 0 dcm_cli_engine
533 0 3928 568 33792 0 0 qos_mon_periodic
509 0 35736 936 33728 0 0 Call Home DS
491 0 41726152 41722888 33560 0 0 SPA ENTITY Proce
183 0 3384 0 33248 0 0 FHRP Main thread
185 0 3312 0 33176 0 0 TRACK Client thr
186 0 3312 0 33176 0 0 VRRP Main thread
60 0 3240 0 33104 0 0 CHKPT RG SCTPthr
177 0 72688 0 33040 0 0 Call Home Timer
59 0 3128 0 32992 0 0 RF SCTPthread
127 0 3120 0 32984 0 0 RF Master Status
510 0 3120 0 32984 0 0 Call Home DSfile
241 0 3120 0 32984 0 0 L2FIB Timer Disp
242 0 3448 200 32984 0 0 MLRIB L2 Msg Thr
169 0 4152 2024 32960 0 0 ACE HAPI
394 0 3104 640 32328 0 0 LFDp Input Proc
41 0 2192 0 32056 0 0 IPC Seat Manager
420 0 2424 448 31840 0 0 URL filter proc
75 0 3600 1728 31736 0 0 IF-MGR control p
500 0 1808 0 31672 0 0 IKEv2 Cluster Lo
232 0 1808 0 31672 0 0 Auth-proxy HTTP
440 0 15314104 15312488 31480 0 0 NIST rng proc
450 0 253432 251984 31168 0 0 crypto engine pr
56 0 268672 2099808 31048 0 0 crypto sw pk pro
156 0 32136 31424 30688 0 0 OVLD SPA Backgro
311 0 992 200 30528 0 0 Service Routing
228 0 896 448 30312 0 0 Spanning Tree
459 0 896 448 30312 0 0 PIM HA
390 0 896 448 30312 0 0 MPLS TP HA
474 0 432 0 30296 0 0 GKM KS PROCESS
149 0 408 0 30272 0 0 Src Fltr backgro
538 0 408 0 30272 0 0 Online Diag CNS
490 0 408 0 30272 0 0 Online Diag EEM
276 0 408 0 30272 0 0 XDR background p
539 0 408 0 30272 0 0 Online Diag CNS
287 0 408 0 30272 0 0 CEF RP Backgroun
344 0 408 0 30272 0 0 XDR FOF process
269 0 200 0 30064 0 0 Marvell wk-a Pow
434 0 0 0 30000 0 0 Key chain liveke
136 0 0 0 29992 0 0 IOSXE-RP FastPat
424 0 0 0 29992 0 0 802.1x Critical
399 0 0 0 29984 0 0 XC RIB MGR
170 0 0 0 29976 0 0 ACE policy loade
42 0 0 0 29976 0 0 IPC Check Queue
622 0 0 0 29976 0 0 IFCOM Msg Hdlr
263 0 0 0 29864 0 0 Spanning Tree St
289 0 0 0 29864 0 0 SNMP Timers
288 0 0 696 29864 0 0 AAA System Acct
290 0 448 448 29864 0 0 PPP Compress Inp
254 0 0 0 29864 0 0 O-UNI Client Msg
253 0 448 448 29864 0 0 OCE punted Pkts
262 0 0 0 29864 0 0 Appnav auto disc
251 0 0 0 29864 0 0 RABAPOL HA
291 0 448 448 29864 0 0 PPP Compress Res
252 0 0 0 29864 0 0 RABAPOL HA IPC f
245 0 0 0 29864 0 0 HDLC HA
299 0 0 0 29864 0 0 IP Traceroute
244 0 0 0 29864 0 0 DVLAN HA
243 0 0 0 29864 0 0 TEMPLATE HA
250 0 0 0 29864 0 0 RG VP
303 0 0 0 29864 0 0 Socket Timers
239 0 0 0 29864 0 0 IGMP Route Msg H
238 0 47585456 47585456 29864 0 0 mcp callhome per
234 0 0 0 29864 0 0 PPCP RP Stats Ba
246 0 448 448 29864 0 0 RG AR
231 0 0 0 29864 0 0 Webauth client
240 0 0 0 29864 0 0 IGMP Route Rx Pr
310 0 448 448 29864 0 0 Dialer Forwarder
264 0 0 0 29864 0 0 CCM
227 0 0 0 29864 0 0 AAA response han
226 0 0 0 29864 0 0 Timed Policy act
225 0 0 0 29864 0 0 Prepaid response
224 0 0 0 29864 0 0 Timer handler fo
221 0 0 0 29864 0 0 SSS Feature Time
317 0 319855688 380074360 29864 0 0 DiagCard1/-1
233 0 0 0 29864 0 0 IP Admin SM Proc
220 0 0 0 29864 0 0 SSS Feature Mana
216 0 0 0 29864 0 0 RIB LM VALIDATE
215 0 0 0 29864 0 0 RADIUS Proxy
322 0 0 0 29864 0 0 RARP Input
212 0 448 448 29864 0 0 PPP Bind
211 0 448 448 29864 0 0 PPP SIP
209 0 0 0 29864 0 0 PM EPD API
208 0 0 0 29864 0 0 AAA EPD HANDLER
207 0 448 448 29864 0 0 MOP Protocols
328 0 448 448 29864 0 0 DHCPv6 LQ client
229 0 0 0 29864 0 0 VRRS
204 0 0 0 29864 0 0 IPv6 ping proces
331 0 0 0 29864 0 0 X.25 Encaps Mana
203 0 448 448 29864 0 0 PIM register asy
329 0 0 0 29864 0 0 PAD InCall
195 0 448 448 29864 0 0 IPAM/ODAP Events
194 0 0 0 29864 0 0 IP Lite session
191 0 448 448 29864 0 0 IP PORTBUNDLE
190 0 0 0 29864 0 0 ISG CMD HANDLER
182 0 560 560 29864 0 0 AAA Dictionary R
339 0 0 0 29864 0 0 Critical Auth
340 0 0 0 29864 0 0 SVM UT Process
341 0 0 0 29864 0 0 DCT Bkgd Process
342 0 0 0 29864 0 0 Timer Handler Pr
343 0 0 0 29864 0 0 VTEMPLATE IPC fl
265 0 0 0 29864 0 0 CCM IPC flow con
345 0 0 0 29864 0 0 RETRY_REPOPULATE
346 0 448 448 29864 0 0 EFP Errd
347 0 448 448 29864 0 0 Ether EFP Proces
348 0 448 448 29864 0 0 Ether Infra RP
349 0 0 0 29864 0 0 CFM HA IPC messa
181 0 0 0 29864 0 0 EAP Test
180 0 0 0 29864 0 0 EAP Framework
282 0 0 0 29864 0 0 FRR Background P
176 0 125904 11024 29864 0 0 TACACS+
354 0 0 0 29864 0 0 ELB HA IPC flow
172 0 448 448 29864 0 0 AAA Server
356 0 0 0 29864 0 0 IGMPSN MRD
357 0 0 0 29864 0 0 IGMPSN
358 0 0 0 29864 0 0 IGMPSN EI L2MCM
359 0 0 0 29864 0 0 IGMPSN EI Timer
360 0 0 0 29864 0 0 IGMPSN EI MRD Ti
361 0 0 0 29864 0 0 TCP HA PROC
362 0 0 0 29864 0 0 BGP HA SSO
171 0 0 0 29864 0 0 RTTYS Process
281 0 0 0 29864 0 0 XDR RP Test Back
365 0 0 0 29864 0 0 IGMPQR
366 0 0 0 29864 0 0 IGMPQR-EI
167 0 0 0 29864 0 0 ASR1K ESMC Proce
166 0 0 0 29864 0 0 TP CUTOVER EVENT
369 0 0 0 29864 0 0 ATM HA IPC flow
370 0 0 0 29864 0 0 FR HA
280 0 0 0 29864 0 0 IPC LC Message H
201 0 0 0 29864 0 0 ICMP event handl
266 0 0 0 29864 0 0 SVM HA
374 0 0 0 29864 0 0 IPv6 ACL RP Proc
375 0 0 0 29864 0 0 Netsync IPC flow
163 0 0 0 29864 0 0 HAL Mailbox
162 0 0 0 29864 0 0 CT3 Mailbox
378 0 0 0 29864 0 0 VRRP HA
161 0 0 0 29864 0 0 CE3 Mailbox
372 0 0 0 29864 0 0 HSRP HA
160 0 0 0 29864 0 0 CWAN CHOCX PROCE
382 0 0 0 29864 0 0 MFI Comm RP Proc
159 0 0 0 29864 0 0 Inter Chassis Pr
158 0 0 0 29864 0 0 MGMTE stats Proc
154 0 0 0 29864 0 0 SSLVPN Register
386 0 448 448 29864 0 0 MPLS VPN HA Clie
387 0 448 448 29864 0 0 TSPTUN HA
153 0 448 448 29864 0 0 ESG MATM process
389 0 448 448 29864 0 0 TE NSR OOS DB Pr
278 0 0 0 29864 0 0 XDR RP Ping Back
152 0 0 0 29864 0 0 ESG PM Main proc
392 0 0 0 29864 0 0 AToM HA Bulk Syn
393 0 0 0 29864 0 0 AToM MGR HA IPC
277 0 0 0 29864 0 0 XDR mcast
147 0 448 448 29864 0 0 FEC_Link_event_h
396 0 448 448 29864 0 0 PPP NBF
275 0 0 0 29864 0 0 802.1x switch
398 0 448 448 29864 0 0 RBSCP Background
267 0 0 0 29864 0 0 AC Switch
400 0 448 448 29864 0 0 ATIP_UDP_TSK
401 0 0 0 29864 0 0 Probe Input
402 0 0 0 29864 0 0 BD Route Msg Hol
403 0 0 0 29864 0 0 BD Route Rx Proc
404 0 448 448 29864 0 0 BD MACSEC HA
405 0 448 448 29864 0 0 BD MACSEC HA CHK
406 0 0 0 29864 0 0 STP HA IPC flow
407 0 0 0 29864 0 0 AAA HA
146 0 0 0 29864 0 0 FPD Action Proce
409 0 0 0 29864 0 0 ac_atm_state_eve
410 0 0 0 29864 0 0 ac_atm_mraps_hsp
411 0 0 0 29864 0 0 AC HA Bulk Sync
412 0 0 0 29864 0 0 ATM HA AC
413 0 0 0 29864 0 0 BFD HA
145 0 0 0 29864 0 0 FPD Management P
415 0 0 0 29864 0 0 CEM HA
416 0 0 0 29864 0 0 CEM HA AC
417 0 448 448 29864 0 0 PPPoE VRRS EVT M
418 0 448 448 29864 0 0 Inspect process
144 0 0 0 29864 0 0 netclk_ha_proces
143 0 448 448 29864 0 0 netclk_process
421 0 0 0 29864 0 0 VFI HA Bulk Sync
422 0 0 0 29864 0 0 VPDN CCM Backgro
423 0 0 0 29864 0 0 MAB Framework
273 0 448 448 29864 0 0 Dot1x Mgr Proces
142 0 0 0 29864 0 0 POS APS Event Pr
426 0 0 0 29864 0 0 Select Timers
141 0 0 0 29864 0 0 fanrp_l2fib
428 0 448 448 29864 0 0 AAA Cached Serve
429 0 448 448 29864 0 0 ENABLE AAA
430 0 0 0 29864 0 0 EM Background Pr
431 0 0 0 29864 0 0 IDMGR CORE
140 0 0 0 29864 0 0 DSX3MIB ll handl
139 0 0 0 29864 0 0 ASR1000-RP SPA A
268 0 0 0 29864 0 0 Inline Power
435 0 448 448 29864 0 0 LINE AAA
137 0 448 448 29864 0 0 NGIO_BRI_POLL_DE
271 0 0 0 29864 0 0 VMATM Callback
134 0 0 0 29864 0 0 AggMgr Process
132 0 0 101532704 29864 0 0 Transport Port A
129 0 448 448 29864 0 0 Compute load avg
124 0 0 0 29864 0 0 IPSEC HA Mgr
442 0 448 448 29864 0 0 CRM_CALL_UPDATE_
123 0 0 0 29864 0 0 IKE HA Mgr
120 0 0 0 29864 0 0 Network-rf Notif
119 0 0 0 29864 0 0 IOSXE-RP SPA TSM
446 0 0 0 29864 0 0 EAP Process
270 0 448 448 29864 0 0 PI MATM Aging Pr
448 0 0 0 29864 0 0 IPSECv6 PS Proc
118 0 0 0 29864 0 0 IOSXE-RP Punt IP
116 0 0 0 29864 0 0 ARP HA
114 0 0 0 29864 0 0 DHCPv6 Server HA
113 0 0 0 29864 0 0 DHCPv6 Relay HA
112 0 0 0 29864 0 0 DHCPD HA
111 0 0 0 29864 0 0 DHCPC HA
110 0 0 0 29864 0 0 CHKPT Test clien
109 0 0 0 29864 0 0 CHKPT Test clien
108 0 0 0 29864 0 0 CHKPT Test clien
458 0 0 0 29864 0 0 COND_DEBUG HA IP
371 0 0 0 29864 0 0 GLBP HA
107 0 0 0 29864 0 0 CHKPT Test clien
106 0 0 0 29864 0 0 CHKPT Test clien
462 0 0 0 29864 0 0 DS0 PCM Capture
105 0 0 0 29864 0 0 CHKPT Test clien
464 0 0 0 29864 0 0 IKEv2 AAA handle
465 0 448 896 29864 0 0 CRYPTO MAP FREE
104 0 0 0 29864 0 0 CHKPT Test clien
103 0 0 0 29864 0 0 CHKPT Test clien
102 0 0 0 29864 0 0 CHKPT Test clien
101 0 0 0 29864 0 0 CHKPT Test clien
100 0 0 0 29864 0 0 CHKPT Test clien
99 0 0 0 29864 0 0 QoS HA ID RETAIN
472 0 0 0 29864 0 0 Crypto PAS Proc
473 0 448 448 29864 0 0 GKM GM Process
447 0 448 448 29864 0 0 Crypto Support
97 0 0 0 29864 0 0 ANCP HA
96 0 0 0 29864 0 0 CWAN IF EVENT HA
94 0 0 0 29864 0 0 CWAN APS HA Proc
93 0 0 0 29864 0 0 100ms check
479 0 197032 636536 29864 0 0 AAA SEND STOP EV
92 0 0 0 29864 0 0 REDUNDANCY peer
550 0 0 0 29864 0 0 IPC ISSU Version
554 0 0 0 29864 0 0 IPC ISSU Version
88 0 0 0 29864 0 0 cpf_process_tpQ
87 0 0 0 29864 0 0 cpf_msg_rcvq_pro
86 0 0 0 29864 0 0 cpf_msg_holdq_pr
85 0 0 0 29864 0 0 RP HA Periodic
84 0 0 0 29864 0 0 Environmental Mo
488 0 448 448 29864 0 0 ICRM
555 0 0 0 29864 0 0 IPC ISSU Version
558 0 0 0 29864 0 0 IPC ISSU Version
626 0 296 296 29864 0 0 DiagCard5/-1
78 0 0 0 29864 0 0 CTS HA IPC flow
493 0 0 0 29864 0 0 SONET Traps
494 0 0 0 29864 0 0 Policy HA Timer
495 0 448 448 29864 0 0 ESG SPAN process
496 0 0 0 29864 0 0 PM Callback
77 0 584 584 29864 0 0 CTS HA
498 0 448 448 29864 0 0 VTPMIB EDIT BUFF
74 0 0 0 29864 0 0 BACK CHECK
71 0 545000 40760 29864 0 0 TTY Background
501 0 448 448 29864 0 0 MCPRP UTD Timer
502 0 0 0 29864 0 0 BGP VA
67 0 0 0 29864 0 0 Critical Bkgnd
66 0 0 0 29864 0 0 Token Daemon
65 0 0 0 29864 0 0 License HA Consi
64 0 288895188320 288895188320 29864 0 0 Licensing Auto U
63 0 0 0 29864 0 0 Image License br
62 0 288 1280 29864 0 0 License Client N
58 0 0 0 29864 0 0 client_entity_se
57 0 0 0 29864 0 0 IOSXE signals IO
55 0 0 0 29864 0 0 SERIAL A'detect
53 0 448 448 29864 0 0 GraphIt
52 0 0 0 29864 0 0 Net Input
49 0 0 0 29864 0 0 Compute SRP rate
48 0 0 0 29864 0 0 SENSOR-MGR event
47 0 0 0 29864 0 0 IPC Session Deta
46 0 0 0 29864 0 0 IPC Loadometer
45 0 0 0 29864 0 0 IPC Keep Alive M
44 0 0 0 29864 0 0 IPC Seat TX Cont
43 0 0 0 29864 0 0 IPC Seat RX Cont
625 0 296 296 29864 0 0 DiagCard4/-1
40 0 0 0 29864 0 0 IPC Process leve
39 0 0 0 29864 0 0 IPC Deferred Por
38 0 0 0 29864 0 0 IPC Periodic Tim
37 0 0 0 29864 0 0 IPC Zone Manager
36 0 0 0 29864 0 0 IPC Service NonC
35 0 0 0 29864 0 0 IPC Dynamic Cach
34 0 0 0 29864 0 0 ASR1000 appsess
33 0 0 0 29864 0 0 IPC Mcast Pendin
32 0 0 0 29864 0 0 IPC Event Notifi
31 0 0 0 29864 0 0 ifIndex Receive
30 0 0 0 29864 0 0 IPC Apps Task
29 0 0 0 29864 0 0 IOSXE heartbeat
28 0 448 448 29864 0 0 ATM VC Auto Crea
624 0 296 296 29864 0 0 DiagCard3/-1
536 0 0 0 29864 0 0 ISSU Utility Pro
537 0 0 0 29864 0 0 IOSXE-RP Virtual
4 0 0 0 29864 0 0 Retransmission o
5 0 0 0 29864 0 0 IPC ISSU Dispatc
25 0 448 448 29864 0 0 Serial Backgroun
541 0 0 0 29864 0 0 IP SLAs Ethernet
542 0 0 0 29864 0 0 IPC ISSU Version
543 0 0 0 29864 0 0 IPC ISSU Version
544 0 0 0 29864 0 0 IPC ISSU Version
24 0 35072 35072 29864 0 0 PrstVbl
546 0 0 0 29864 0 0 IPC ISSU Version
547 0 0 0 29864 0 0 IPC ISSU Version
548 0 0 0 29864 0 0 IPC ISSU Version
549 0 0 0 29864 0 0 IPC ISSU Version
8 0 0 0 29864 0 0 RO Notify Timers
551 0 0 0 29864 0 0 IPC ISSU Version
552 0 0 0 29864 0 0 IPC ISSU Version
553 0 0 0 29864 0 0 IPC ISSU Version
11 0 0 50235816 29864 0 10360224 DiscardQ Backgro
12 0 448 448 29864 0 0 Timers
556 0 0 0 29864 0 0 IPC ISSU Version
557 0 0 0 29864 0 0 IPC ISSU Version
14 0 0 0 29864 0 0 MEMLEAK PROCESS
559 0 0 0 29864 0 0 IPC ISSU Version
560 0 0 0 29864 0 0 IPC ISSU Version
561 0 0 0 29864 0 0 IPC ISSU Version
562 0 0 0 29864 0 0 IPC ISSU Version
563 0 0 0 29864 0 0 IPC ISSU Version
564 0 0 0 29864 0 0 IPC ISSU Version
565 0 0 0 29864 0 0 IPC ISSU Version
566 0 0 0 29864 0 0 IPC ISSU Version
567 0 0 0 29864 0 0 IPC ISSU Version
568 0 0 0 29864 0 0 IPC ISSU Version
569 0 0 0 29864 0 0 IPC ISSU Version
570 0 0 0 29864 0 0 IPC ISSU Version
571 0 0 0 29864 0 0 IPC ISSU Version
572 0 0 0 29864 0 0 IPC ISSU Version
573 0 0 0 29864 0 0 IPC ISSU Version
574 0 0 0 29864 0 0 IPC ISSU Version
575 0 0 0 29864 0 0 IPC ISSU Version
576 0 0 0 29864 0 0 IPC ISSU Version
577 0 0 0 29864 0 0 IPC ISSU Version
578 0 0 0 29864 0 0 IPC ISSU Version
579 0 0 0 29864 0 0 IPC ISSU Version
580 0 0 0 29864 0 0 IPC ISSU Version
581 0 0 0 29864 0 0 IPC ISSU Version
582 0 0 0 29864 0 0 IPC ISSU Version
583 0 0 0 29864 0 0 IPC ISSU Version
584 0 0 0 29864 0 0 IPC ISSU Version
585 0 0 0 29864 0 0 IPC ISSU Version
586 0 0 0 29864 0 0 IPC ISSU Version
587 0 0 0 29864 0 0 IPC ISSU Version
588 0 0 0 29864 0 0 IPC ISSU Version
589 0 0 0 29864 0 0 IPC ISSU Version
590 0 0 0 29864 0 0 IPC ISSU Version
591 0 0 0 29864 0 0 IPC ISSU Version
22 0 448 448 29864 0 0 DDR Timers
593 0 0 0 29864 0 0 IPC ISSU Version
594 0 0 0 29864 0 0 IPC ISSU Version
595 0 0 0 29864 0 0 IPC ISSU Version
596 0 0 0 29864 0 0 IPC ISSU Version
597 0 0 0 29864 0 0 IPC ISSU Version
598 0 0 0 29864 0 0 IPC ISSU Version
599 0 0 0 29864 0 0 IPC ISSU Version
600 0 0 0 29864 0 0 IPC ISSU Version
601 0 0 0 29864 0 0 IPC ISSU Version
602 0 0 0 29864 0 0 IPC ISSU Version
603 0 0 0 29864 0 0 IPC ISSU Version
604 0 0 0 29864 0 0 IPC ISSU Version
605 0 0 0 29864 0 0 CWAN OIR IPC Rea
20 0 0 0 29864 0 0 AAA_SERVER_DEADT
19 0 0 0 29864 0 0 CEF MIB API
18 0 0 0 29864 0 0 ATM ASYNC PROC
609 0 296 296 29864 0 0 DiagCard2/-1
611 0 0 0 29864 0 0 TCP Listener
17 0 448 448 29864 0 0 ATM Idle Timer
16 0 303070568 324703856 29864 0 0 ARP Background
397 0 880 448 18296 0 0 PfR BR Learn
318 0 408 0 18272 0 0 Secure Login
179 0 408 0 18272 0 0 ADJ NSF process
83 0 448 448 17864 0 0 PuntInject Keepa
89 0 0 0 17864 0 0 CEF RRP RF waite
13 0 0 0 17864 0 0 WATCH_AFS
164 0 448 448 17864 0 0 MIP Mailbox
91 0 0 0 17864 0 0 XDR RRP RF waite
2 0 448 448 17864 0 0 Load Meter
380 0 448 448 17864 0 0 L2X Switching Ev
26 0 0 0 17864 0 0 RMI RM Notify Wa
82 0 0 0 17864 0 0 Punt FP Stats Du
0 0 288 33319080 288 0 0 *Sched*
1420485936 Total
Output for show processes memory allocated. Thanks
PCGRT2101#sh processes memory sorted allocated
Processor Pool Total: 1688346960 Used: 1414924520 Free: 273422440
64 0 328444327080 328444327080 29864 0 0 Licensing Auto U
15 0 10491123080 10490982872 170072 0 0 ARP Input
623 0 5068964888 2490347696 864274616 0 0 BGP Router
117 0 5066508960 334733616 45664 0 0 IOSXE-RP Punt Se
617 0 4583336664 6797461032 114192 0 0 SNMP ENGINE
10 0 2485478536 2494687192 215224 2376618249 2378537977 Pool Manager
616 0 2214140944 0 101864 0 0 PDU DISPATCHER
606 0 1667233352 1667233192 54024 0 0 mdns Timer Proce
615 0 1602674224 1602668264 55568 0 0 IP SNMP
300 0 1484395184 2167034584 231122664 12250980 0 IP RIB Update
200 0 1217406816 8448 53864 0 0 IP Input
0 0 986804336 981040320 3843384 8177103 0 *Dead*
512 0 658267992 362552328 243136 0 0 BGP Task
317 0 362859792 430941480 29864 0 0 DiagCard1/-1
16 0 331135808 352769096 29864 0 0 ARP Background
175 0 229252704 426936384 173128 0 0 BGP I/O
486 0 214534160 214518216 45808 0 0 Syslog Traps
79 0 75608000 14104 7594632 0 0 IOSD ipc task
620 0 65465872 65455080 77936 0 0 SNMP Traps
238 0 54885024 54885024 29864 0 0 mcp callhome per
491 0 47676264 47672552 34008 0 0 SPA ENTITY Proce
332 0 34042480 34042480 41864 0 0 QoS stats proces
305 0 18394136 5810213376 56136 0 0 TCP Protocols
440 0 17384168 17382552 31480 0 0 NIST rng proc
438 0 14187360 7907184 56272 0 0 TPLUS
530 0 4636240 4633272 56832 0 0 Syslog
3 866 1876032 1745808 176192 0 0 SSH Process
71 0 545000 44600 29864 0 0 TTY Background
56 0 268672 2269856 31048 0 0 crypto sw pk pro
479 0 216144 696080 29864 0 0 AAA SEND STOP EV
176 0 129328 11240 29864 0 0 TACACS+
72 0 448 30408 53976 0 0 SXP CORE
0 0 288 34828904 288 0 0 *Sched*
304 0 0 4836992 53864 0 0 TCP Timer
206 0 0 831794992 41864 0 0 BGP Scanner
132 0 0 109014752 29864 0 0 Transport Port A
1420752328 Total
PCGRT2101#
It looks like BGP is consuming a huge chunk.  Try reducing the number of prefixes (perhaps filtering out 25 to 32 length prefixes), or add more RAM.
Philip D'Ath
This might be more useful:
