Memory on ASR1002X
BONG SO
Dear all,
I have a Cisco ASR1002X (running 15.2) with 4G physical memory installed. However, i found that only around 1.1G memory is usable by the IOSd:
cisco ASR1002-X (2RU-X) processor with 1156392K/6147K bytes of memory.
Processor board ID SSI16500G0G
6 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
6684671K bytes of eUSB flash at bootflash:.
According to the following document, ASR1000 could get around 2G memory for IOSd on a 4G physical memory system:
http://www.cisco.com/en/US/products/ps9343/products_tech_note09186a0080af252a.shtml
Upon startup, IOSd is granted access to a fixed amount of physical memory on the RP typically 50 percent or 1 GB on 2 GB systems and 2 GB on 4 GB systems.
I did not enable software redundancy so i expect i could have ~2G for the IOSd. Is that any memory to increase the memory or it is not changable?
Router#show redundancy
Redundant System Information :
       Available system uptime = 10 minutes
Switchovers system experienced = 0
              Standby failures = 0
        Last switchover reason = none
                 Hardware Mode = Simplex
    Configured Redundancy Mode = Non-redundant
     Operating Redundancy Mode = Non-redundant
              Maintenance Mode = Disabled
                Communications = Down      Reason: Failure
Current Processor Information :
               Active Location = slot 6
        Current Software state = ACTIVE
       Uptime in current state = 10 minutes
                 Image Version = Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.2(4)S, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 23-Jul-12 20:03 by mcpre
                          BOOT =
        Configuration register = 0x2102
Bong So
0 Replies 0
