Meraki AP on Cisco 3560-X Poe Switch
bruce.thornton
We are looking at the option of install a Meraki AP at a remote site in instead of a Cisco 2802i access point. We will upgrade the IOS on the 3560-X to ipservices to support VRF tunnels for Guest Internet needed at the location. My question is, can the Meraki Access Point be install on the 3560-X?
andre.ortega
Yes, Meraki AP can be connected to Cisco 3650X.
Will you use PoE? Please check the exact model of the AP and switch, only to confirm it will have enough power.
andre.ortega
That helped me decide. Thanks.
