message not identified
alex-pavezi
Frequent Visitor
Frequent Visitor
i receive the follow message in customer with c6509 and sup720: "RELIABILITY DRIVER: wrong signature on NVFLASH", somebody knows what it can be?
garytayl
Level 7
Level 7
If you are getting that message at boot up, you might be hitting bug CSCsa96894.
Using a valid CCO, you can see the details at:
http://www.cisco.com/cgi-bin/Support/Bugtool/launch_bugtool.pl
I suggested the solution it customer and when it will have the reply I will go to postar for you. thaks.
I'm also experiencing the same message appearing and I have seen the details of the bug and its workaround. Unfortunately, the workaround doesn't work. The message is still there. After copying the image contained in the sup-bootflash to disk0, formatting it, and copying it back again, the message still appears.
Did I get the process right?
